XMOS-based Asynchronous USB to I2S interface - Page 191 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 1st December 2013, 05:50 PM   #1901
carsten.witt's Avatar
i think it is USB via jack or over J1
[EDIT]add a PDF
Old 1st December 2013, 07:38 PM   #1902
Thanks very much Carsten...!
Old 2nd December 2013, 07:05 AM   #1903
Originally Posted by Ian Millar View Post
Lucian, may I ask - what is the actual "source voltage" across each LED take-off? In a previous post in this thread a member suggested to another that he place a 5K resistor in series with a standard LED to limit current to your specified 8mA, but 5K seems very high. If the "source voltage" is (say a guess) 3.3V, and your LED has a 2V drop, then the resistor ought to be around 180R in order to limit current to 8mA. However we need the actual "source voltage" to calculate this.
Hi Ian, I presume you're referring to my #1428 post.
You're correct, my reply can be misinterpreted. The resistor value depends on what current you want. 8mA caused real brightness with my leds.
If you really want 8mA, ~180R is the correct value.
I confirm I was using 5k resistor, I wanted the leds very dim.
The Led Vout is around 3.1V (#1124), on my board.
Old 2nd December 2013, 09:17 AM   #1904
Thank you m.massimo. Yes and thanks for the perfect info. Now I see your post #1124 which I could not have found so easily way-way back in such a long thread otherwise. Cheers.
Ian
Old 5th December 2013, 07:18 PM   #1905
Hello!
Is there anybody who knows if the WaveIO USB module can be placed under a DAC (maybe 4-5 cm under a DAC pcb) without any problems - soundwise or other -regarding EMI or RF etc.? Maybe some kind of shielding is necessery?
Vidar
Old 6th December 2013, 12:02 AM   #1906
I just bought some Stillpoints ERS sheets. Maybe they can make digital a bit easier in cramped places. ERS
Old 7th December 2013, 08:58 PM   #1907
jrling is offline jrling  United Kingdom
Originally Posted by Lorien View Post
I have plans to do it these days because I must reserve some time for this task since there are couple of custom driver I need to build besides WaveIO. Even if I looked into the revision document I'm curious what 'huge' updates are you talking about?
Lorien - any luck with the new Thesycon drivers for us WaveIO users?
Do you have to change the software or is it just a matter of putting them on your website?
Thanks Jonathan
Old 9th December 2013, 05:27 PM   #1908
How about new drivers ? 2.15 version.
Generic package is online since 31.10.2013 on XMOS webpage.
Old 10th December 2013, 10:05 PM   #1909
Hi Lorien,
I am trying out the UFL connections from wave IO to dddac but this is unsuccesfull now. I have connected data, BCK, LR and GND of the dac to the UFL connectors of wave IO.
Sound is distorted, mostly noise with the music on back ground.
Am I doing something wrong?
Old 10th December 2013, 11:14 PM   #1910
Hi Ss!
Data, LR, and Bck should work. Don't forget to connect ground to H4......and put 3.5 to 5Volts on pin 5 of the bigger connector, next to the Ufl's. This is what the isolator needs to get working!
Ed
Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface minidsp miniDSP 40 22nd October 2015 08:46 PM
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1361 5th April 2015 01:43 PM
Ultimate USB to I2S interface sampler Digital Source 206 30th January 2012 04:45 PM
Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? cxhawk Digital Source 7 3rd December 2010 03:30 PM
interface I2S with USB mermoz Digital Source 0 21st February 2003 11:34 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
