XMOS-based Asynchronous USB to I2S interface - Page 172 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 1st May 2013, 05:15 AM   #1711
Originally Posted by Ben Mah View Post
The TDA1541a in simultaneous mode (I2S input) accepts up to 96 kHz only as far as I know. For 192 kHz, simultaneous mode with separate data L to pin 3 and data R to pin 4 is required. The WaveIO does not provide this output. Iancanada has something coming out in groupbuy that can do this.
Thanks Ben!
I went through the thread and it seems iancanada has some problem too with normal continuous clock operation, read the post #389.
Drive NOS AD1865/62,PCM1704/02/63,TDA1541 from FIFO: Universal I2S-PCM driver board
Old 8th May 2013, 12:45 PM   #1712
manudrz is offline manudrz  France
Some news about an update firmware and/or drivers ?
Old 9th May 2013, 05:46 PM   #1713
Drivers don't need to be updated as are reported to be stable... not to mention that there's nothing new from XMOS on this side. Firmware, though, is another story. I managed to make WaveIO work on 32/384 but the software is not fully tested. I could release a bin file and make a pdf with instructions on how to update the EEPROM contents but only if there are few who want to become beta testers.
Kind regards,
L
Contact link for WaveIO USB-to-I2S/SPDIF board.
Daughter card GB list for WaveIO can be found here
Old 9th May 2013, 06:30 PM   #1714
lindamar's Avatar
Location: Madrid - Capital of the Kingdom of Spain / European Union
Here is one volunteer for starters ....
My setup: Macbook Pro w/ Mac OSX Mountain Lion (it could run win7 if you "force" me to... )
cheers
Pepe
Old 11th May 2013, 03:43 PM   #1715
triode_al's Avatar
The TDA1541 accepts up to 176,4 kHz (4-f OS) and the A-version higher even in 8-fold OS:
FUNCTIONAL DESCRIPTION
The TDA1541A accepts input sample formats in time multiplexed mode or simultaneous mode up to 16-bit word length.
The most significant bit (MSB) must always be first. The flexible input data format allows easy interfacing with signal processing chips such as interpolation filters, error correction circuits, pulse code modulation adaptors and XMOS digital signal processors (DSP).
The high maximum input bit-rate and fast setting facilitates application in 8 ´ oversampling systems (44.1 kHz to 352.8 kHz or 48 kHz to 384 kHz) with the associated simple analog filtering function (low order, linear phase
filter).
The chip documentation does not specify that a specific mode is needed for a higher rate.
But I have seen that Philips some way or another pushed the chip into a 18-bits mode. And I remember this was the case in the Sony DAS R1.
SPU --> two stage RIAA; Kaneda pre; 300B SE no feedback; Open Baffle, Lowther
Old 19th May 2013, 08:15 AM   #1716
Dear Lorien ... Can you share with us your project timeline for the Daughter board to be completed? Many thanks!
Old 20th May 2013, 02:43 AM   #1717
doylep is offline doylep  Australia
Default Najda Support
Hi Lorien,
Can you let me know if there will be many issues getting I2S working with the Najda board ? I am looking for a USB I2S solution for Najda.
I believe you and Nick are working on a soultion.
Regards Peter.
Old 20th May 2013, 06:10 AM   #1718
Today or tomorrow I'll finally finish the actual design which, I guess, few of you already know something about it but I'll post the details when is done. As usual, it was turned to layout stage right before the manufacturer was ready to build the masks for the PCB as I had to make some last minute changes to improve its functionality. Beating designs to death and squeezing all what's left of it is something usual now and I'm used to that! The bottom line is that I'll be fully devoted to daughter card after this new board will be done.
Originally Posted by doylep View Post
Hi Lorien,
Regards Peter.
I do not know yet why there's a problem wiring WaveIO to Najda card when things are looking good to me (?)... at least from theoretical side! Anyway, we're working together to find the source of the problem and solve it thus the first step will be to exchange boards and run few parallel tests in same configuration. For now I'll wait for him to come back to office, which I guess it will be tomorrow, and send the test WaveIO board asap.
Kind regards,
L
Old 21st May 2013, 12:01 AM   #1719
Great to hear you guys are working together on the solution, myself along with others would be very appreciative.
Old 21st May 2013, 04:11 PM   #1720
@ doylep: Let's hope it will come out something good from this experiment
BTW, I changed my first post of this thread just to show you the steps you need to follow to update the stock WaveIO's firmware for 32 @ 384 KHz sample rate (Pepe? ).
Enjoy,
L
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1372 11th June 2016 06:40 PM
Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface minidsp miniDSP 40 22nd October 2015 07:46 PM
Ultimate USB to I2S interface sampler Digital Source 206 30th January 2012 03:45 PM
Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? cxhawk Digital Source 7 3rd December 2010 02:30 PM
interface I2S with USB mermoz Digital Source 0 21st February 2003 10:34 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
