XMOS-based Asynchronous USB to I2S interface - Page 163 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 22nd January 2013, 06:34 PM   #1621
Sandor is offline Sandor  Italy
Originally Posted by Lorien View Post
@ Sandor: If you have a 40-wire PATA ribbon cable used for Optical drives or HDDs then you can use it for your connections. Seems that I can't find any suitable video on youtube that shows you how to use IDC connectors with ribbon cables. I'll continue searching and email the link if I'll find any.
L
Hi Lucian,
is this connector suitable for isolated I2S outputs?
IDD-05-G - SAMTEC - RICETTACOLO, 2.54MM, IDC / IDT | Farnell Italia
Old 22nd January 2013, 07:30 PM   #1622
And is this a suitable cable?
3-1437366-9 - TE CONNECTIVITY / AMP - CAVO PIATTO, A 10 VIE, PER M | Farnell Italia
Old 22nd January 2013, 11:40 PM   #1623
wlowes is offline wlowes  Canada
wlowes's Avatar
Originally Posted by Patrik1005 View Post
Hello Pet-240
Alsa is to 100%, will be recognized as waveIO Device0 subd 0
it is also entered in mpd.conf
the sound-test and mpd brings no sound with waveio, with miniUSB of dsp4you is the sound present with audio-test and mpd
(horrible sound ),
Windows and WaveIO works fine
first time WaveIO run with super sound on alixboard with voyagempd. Only since the Windows test it no longer works.
Same result after power WaveIO with USBPower and Restart ...
Still sounds like it is muted in Alsa. Try toggling mute on and off. There is a lot of discussion on the MPDPUP site. There is a well documented problem with the WaveIO showing up with mute on in Alsa under various scenarios. It is not hard to unmute but can be baffling the first time.
Old 23rd January 2013, 12:03 AM   #1624
PET240 is offline PET240  Australia
if muted there will be an M at the bottom of the volume slider, when not muted it will be the infinity symbol(sideways 8).
Old 23rd January 2013, 10:12 AM   #1625
I use Voyage MPD, with the command amixer on the console I set the volume to 100% and set "unmute". Also switch between mute and unmute brings no change.
Old 23rd January 2013, 10:40 AM   #1626
ENSen is offline ENSen  Sweden
Hi Patrik,
Type
cat /proc/asound/cards
And post the result here.
Old 23rd January 2013, 11:14 AM   #1627
bonalux is offline bonalux  Italy
Please read this thread;
Puppy Linux Discussion Forum :: View topic - mpdPup - Simplified MPD Music Server/Jukebox - v0.9.3
as wlowes said, there is a known problem with mpd and WaveIO, after a bit of grinding i've managed to let it work consistently, but with a self powered WaveIO, at startup i have to always start first the alix and after say, 2 minutes, the WaveIO, otherwise it will not be recognised.
Gianluca
Old 23rd January 2013, 12:24 PM   #1628
Hi ENSen
cat ...
Simple mixer control 'Luckit Clock Selector',0
Capabilities: pvolume pswitch penum
Playback channels: Front Left - Front Right
Limits: Playback 0 - 127
Mono:
Front Left: Playback 127 [100%] [0.00dB] [on]
Front Right: Playback 127 [100%] [0.00dB] [on]
Simple mixer control 'Luckit Clock Selector',1
Capabilities: pvolume pvolume-joined pswitch pswitch-joined penum
Playback channels: Mono
Mono: Playback 127 [100%] [0.00dB] [off]
root@voyage:~# cat /proc/asound/cards
0 [L20]: USB-Audio - Luckit USB Audio 2.0
Luckit Luckit USB Audio 2.0 at usb-0000:00:0f.5-1, high speed
to bonalux
the alix with mpd is always on , waveio powerd with extern supl.
I will read the Therad
Old 23rd January 2013, 12:31 PM   #1629
only this sorry
0 [L20 ]: USB-Audio - Luckit USB Audio 2.0
Old 23rd January 2013, 03:05 PM   #1630
Hello
Errors found, Mono was on mute
I'm not clear why this has efekt, but it goes
Thanks to all
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1372 11th June 2016 06:40 PM
Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface minidsp miniDSP 40 22nd October 2015 07:46 PM
Ultimate USB to I2S interface sampler Digital Source 206 30th January 2012 03:45 PM
Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? cxhawk Digital Source 7 3rd December 2010 02:30 PM
interface I2S with USB mermoz Digital Source 0 21st February 2003 10:34 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
