XMOS-based Asynchronous USB to I2S interface - Page 160 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 13th January 2013, 06:43 PM   #1591
bonalux is offline bonalux  Italy
Originally Posted by staki View Post
Did you try to use a master/slave power strip ? With the pc on the master side and the waveio on the slave side ?
I am not sure at all, but that could help......
Tried a powerstrip but same problem. Maybe it's related with mpdpup, but other usb converters worked well with mpdpup, the developer it's still trying to find a clue on the problem, but for the moment i'm happy as it is, only thing is that i have to power on the Alix board and after 2-3 minutes the WaveIO and all it's fine.
Gianluca
Old 13th January 2013, 06:59 PM   #1592
jrling is offline jrling  United Kingdom
For now I have all my files on a SATA HDD. But it is formatted in NTFS. I don't know if mpdPup can read the NTFS partitions, or if I have to reformat the whole HDD in ext3 or another Linux format.
To date I believe NTFS is not supported in mpdPup.
Old 14th January 2013, 09:22 AM   #1593
Previous versions had a bug now solved in the last version.
Old 14th January 2013, 10:00 AM   #1594
staki is offline staki  Switzerland
Good news !
Old 14th January 2013, 10:13 AM   #1595
In my previous configuration i had mpdpup installed in a NTFS SSD, but now in server configuration more capacity is allowed, needed for HD files. Using USB hard drive doesn't seem a good solution and it has some problems too.
Old 15th January 2013, 01:19 PM   #1596
SPDIF no signal.
I connected the WaveIO to FIFO via the isolated I2S and work excellent, but no sound when connect through the SPDIF, neither the isolated or non-isolated. Even directly connect it to BIII, still no sound. Scope shows no output from the SPDIF. Please advise what may be the problem.
Old 17th January 2013, 02:33 PM   #1597
Hurrah !!
I got the WaveIO card today after some very nasty adventures !
A neighbour of mine tried to steal the parcel from the postman !
But I threatened to call the police and finally he gave me the card back.
To all the owners of the WaveIO card. Keep it carefully, because it is sooooo good that some people try to steal it !!
It is world glory for Lucian !
I am delighted to be able to listen to it soon.....
Many thanks Lucian !
Old 17th January 2013, 02:46 PM   #1598
Hello, want to upgrade a Behringer DCX 2496 with the Wave IO board. For this I have following question:
Is it possible fixing the output rate of the board to 24 bit / 96 kHz with the software? I mean, that incoming lower rates would be up sampled, and incoming higher rates would be down sampled. With the fixed sample rate out of the Wave IO board it would be possible to connect the board via I2S to the DCX 2496 without using the SRC CS 8420?
I am very pleasure, for some details or solutions!
Thanks! Rainer
Old 17th January 2013, 03:59 PM   #1599
How is your daughter Lorien? )
Old 17th January 2013, 04:32 PM   #1600
Hi Lorien,
How to get the cables for the I2S output?
Is it called micro BNC cable?
Gary
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1372 11th June 2016 06:40 PM
Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface minidsp miniDSP 40 22nd October 2015 07:46 PM
Ultimate USB to I2S interface sampler Digital Source 206 30th January 2012 03:45 PM
Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? cxhawk Digital Source 7 3rd December 2010 02:30 PM
interface I2S with USB mermoz Digital Source 0 21st February 2003 10:34 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
