XMOS-based Asynchronous USB to I2S interface - Page 16 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 1st November 2011, 12:27 PM   #151
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
His point was perfectly clear to me
The smart way to keep people passive and obedient is to strictly limit the spectrum of acceptable opinion, but allow very lively debate within that spectrum. Chomsky
Old 1st November 2011, 12:27 PM   #152
Turbon is offline Turbon  Sweden
Turbon's Avatar
Now we are moving. What is jitter (we know this)? How much were allowed if quantification methods were available at the time on implementation? If not, what is the best method to measure it so it would be understandable by the average buddy/Joe/Clarissa (me:-))
Brgds
Old 1st November 2011, 12:35 PM   #153
OK, elucidate it.
Let's face it, you two are simply seeking to dispute with anybody you think might be competent to put up a good argument.
Old 1st November 2011, 12:37 PM   #154
abraxalito's Avatar
Originally Posted by counter culture View Post
OK, elucidate it.
You're trolling. Is that clear enough?
Old 1st November 2011, 12:38 PM   #155
No, I'm not.
Old 1st November 2011, 12:42 PM   #156
Turbon's Avatar
Now, c'mon friends. We are probably all twisting strings on subjects where there are no commonly agreed answers yet. Thats a definition to me of an emerging standard...
The first step would be to bombard MS with request for a uac2 common driver and build the hw from there.
Yupp, I have sent my wishes to ms. Whatever they decide will of course set the baseline even if we know better ;-)
Brgds
Old 1st November 2011, 02:48 PM   #157
Bunpei is offline Bunpei  Japan
I do not favor the term "jitter", but "phase noise".
You can look at "phase noise plot" on this page.
phase noise definition
In this example, the plot is for a master clock.
I wish we could measure a phase noise for MCLK, LRCLK, BCLK signal of I2S just at input pins of DAC chip.
Old 1st November 2011, 03:56 PM   #158
Default I2S and async USB...
1. For I2S you have: data, bit clock, word clock, and master clock:
Some DACs, will not need masterclock, as they will be using their own and reclocking-aligning the master clock to the bit clock. But best performance will be realised with one oscillator producing both the masterclock and bit clock, so that no realigning (PLL) is needed, as long as the provided clock is low in phase noise.
2. For I2S the sender does not have to be the master. For example, again the Ayre QB-9: the two oscillators are on the DAC board, close to the DAC chip, and then the master clock signal is sent back over I2S to the USB receiver (which is XMOS based). The DAC board is powered by a separate supply from the USB receiver board, hence the oscillators get a clean supply.
Lorien, could the new rev be made with the option to accept masterclock in to accommodate the approach used in "2" above?
Old 1st November 2011, 05:17 PM   #159
reo is offline reo  Canada
hi folks
little off beat question... but necessary for me to join my buffaloII with WaveI/O.
WaveI/O has outputs provision of MCLK, LRCLK, BCLK and DATA , now where do they in relation with the BuffaloII inputs of the I2S, there the SCL,SDA, GND,and DVCC .,
i don't understand the abreviation of those terms that are used for the I2S inputs on the Buffalo dac , i looked and looked but to no avail .
any help is appreciated .
regards
rols.
Old 1st November 2011, 06:06 PM   #160
Originally Posted by reo View Post
hi folks
regards
rols.
apology ...wrong forum .
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1368 28th April 2016 04:39 AM
Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface minidsp miniDSP 40 22nd October 2015 07:46 PM
Ultimate USB to I2S interface sampler Digital Source 206 30th January 2012 03:45 PM
Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? cxhawk Digital Source 7 3rd December 2010 02:30 PM
interface I2S with USB mermoz Digital Source 0 21st February 2003 10:34 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
