| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#1571 |
Happy new year to all the diyers !
#1572 |
HNY everyone !
![]() I have a question, I didn't find any answer in the topic about it... Do this Xmos chip can let passthrough AC3 and DTS multi-channels streams ? |
#1573 | |
Any follow up on this product and the wave card ? thanks kp93300 |
#1574 |
#1575 |
Hi all and happy new year!
I want to report my experience with the WaveIO: finally after more than three months working (in the spare time obviously ) on rebuilding my dac, i've manged to finish it and do some serious listening test, well, reading the post in this forum my expectations were high, but they had been exceeded a long way!! ![]() Onestly, never listened to such beautiful sound coming from speakers, and i'm sure much of the merit is for the WaveIO, because my dac was only tweaked a bit (double PCM1704K in nos mode with resistor I/V conversion and jfet amplifier + buffer, i'm using isolated I2S output) in the psu. Lucian philosophy of very good psu and well engineered layout (that is also mine) it's for sure a winner. I'm listening it thru an Alix 3d2 board with mpdpup 0.9.3a installed with the stock tweaks, music files are on a separate nas, very short (0,5 mt) and high quality usb cable, highly recommended! At this point i don't think is it possible to gain much more from such a high quality card Lucian, but i'm looking forward to see your next project i'm always ready to be wrong.DIY it's a never ending story! Bye. P.S.: just to tell the whole story, with the WaveIO i've found one little problem and is that if you boot the card before the pc (or you have to reboot the pc but don't turn off the WaveIO), the card is not recognised at the restart, and you have to turn it off and on to let it work again. It's surely an hardware/firmware problem of the card, because also with windows there is the same problem and chances are that it's due to the fact i'm powering the card with a separate psu and not from the usb. Powering from the usb probably the card is resetted with the pc when you reboot, i say probably, never tested it.
Gianluca Last edited by bonalux; 12th January 2013 at 07:49 AM. |
#1576 |
I came to a similar conclusion...with a Alix 1 card and a sotm usb-card which gives you even more natural sound than the Alix 3d2 which I tried as well...still woundering if the isolator chip i use from the waveio card should really get its power froma sep.supply or from the Buffalo Dac to have the same ground and psu noise ?
#1577 |
#1578 | |
@Blitz: did you experience the same problem on reboots as mine?
Gianluca Last edited by bonalux; 12th January 2013 at 04:10 PM. |
#1579 | |
I am not sure at all, but that could help...... |
#1580 | |
| exaU2I - Multi-Channel Asynchronous USB to I2S Interface | exa065 | exaDevices | 1303 | 10th May 2013 05:19 PM |
| Ultimate USB to I2S interface | sampler | Digital Source | 206 | 30th January 2012 03:45 PM |
| Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface | minidsp | miniDSP | 35 | 13th January 2012 07:02 PM |
| Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? | cxhawk | Digital Source | 7 | 3rd December 2010 02:30 PM |
| interface I2S with USB | mermoz | Digital Source | 0 | 21st February 2003 10:34 AM |
