XMOS-based Asynchronous USB to I2S interface - Page 142 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 25th October 2012, 02:00 PM   #1411
triode_al's Avatar
Originally Posted by Lorien View Post
Okay, my english language skills are killing all of us
L
Thanks, perfectly clear, and yes, daughters are connected to mothers, and i figured out long ago that wave-io was the mother of all asynchronous interfaces
SPU --> two stage RIAA; Kaneda pre; 300B SE no feedback; Open Baffle, Lowther
Old 25th October 2012, 05:45 PM   #1412
Originally Posted by hochopeper View Post
2. Isolated i2s from J6 header. Use IPC cable from header to supply i2s to DAC and provide the required logic voltage (is your dac's i2s input expecting 5V logic or 3v3?) as input to the appropriate pins on the header.
interesting observation, so I wonder how can this device be set in order to provide these two different voltage I2S signals for the different type of DAC(s)?
I mean that some DAC needs 3,3V I2S signal, others (like mine) need 5V I2S signal - so how can this be achieved with this WAVE I/O motherboard?
== There are no limitations to the self except those you believe in ==
Old 25th October 2012, 05:48 PM   #1413
BrianDonegan's Avatar
Typically, 5V logic will work with 3.3V signals, but not the other way around.
Old 25th October 2012, 10:17 PM   #1414
JLOP is offline JLOP  France
Sorry for not replying earlier. I forgot to come back.
I hope you are kidding Chris
Thanks a lot, you are really helpful. I gotta dig your answer and make a drawing to make sure I understood everything properly for the cabling.
I joined schematic from my Dac, seems that the DAC is fed in 5v. I will study datasheets more in detail to check where exactly insert the I2S, should i understand that it is right in the DAC chip after the 74C02. I will study Ian's thread too.
BR from Paris
Jean-Louis
Old 26th October 2012, 12:19 AM   #1415
Provide 5V on V+ pin of J6 and the i2s on J6 will be 5V and isolated from the computer/fpga noise as well
As Brian has said above, typically 3.3V i2s -> 5V logic (DAC inputs or ttl logic gates) will work ok. 5V logic -> a device expecting 3.3V logic is not recommended, likely will end badly for that DAC chip(s).
Edit: If you check your DAC datasheet, it should specify low/high cut-off levels and a voltage tolerance on the digital input pins.
Old 26th October 2012, 12:26 AM   #1416
BR from Paris
Jean-Louis
If you're using the AD1865, certainly check and ask questions in Ian's I2S to PCM thread and FIFO also. The i2s to pcm coverter is a great solution to this problem.
If you use Ian's conversion board then you would connect this to the DAC inputs (bypass the nor logic gates). If you use WaveIO directly you must connect via the logic to convert i2s to a pcm signal that your dac is expecting. The issue that Ian's board addresses is that there is variations in the logic gate operation time, this adds jitter to the signal regardless of how good the transport might be. Ian's board performs a similar conversion, but does the conversion better IMO and then performs a re-clocked stage for minimum jitter before connecting to your DAC.
Old 28th October 2012, 03:42 AM   #1417
Cool Me tooo...
Returning to this thread after more than a year.
In contrast to most other users of WaveIO, my experience is that regardless of ground noise from non-isolated I2S, my TDA1541A based DAC still sound better with it than isolated I2S of current WaveIO. This is my personal opinion and I have no measurements to prove it.
Nonetheless, I wish to have USB isolation without resultant higher jitter from NVE IL715. Thus,
One daughter board for me as well:
1. hirez69
2. analog_sa
3. m.massimo
4. ozlegend
5. luisbock
6. vitalica
7. palmito
8. gabanyayaya
9. danny_66
10. shoom
11.12. kp93300 X 2
13. lindamar
14. merlin el mago
15. Reo
16. arkadiush1
17. jmltinc
18. zibra
19. tagheuer
20. hochopeper
21. hacker
22. Bemused
23. vanwykca
24. sandor
25. jrling
26. bismuth
27. necplusultra
28. flocchini
29. ichiban
30. edbk
31. Nikon1975
32. pawlus
33. dubai2000
34. henri47
35. presapian
36. Corpius
37. Ryssen
38. carsten.witt
39. Sidiropa
40. Ryelands
41. krautxy
42. 43. 44. 45. Mats x 4
46. ecchecequa
47. 48. lm1no2 x 2
49. Magsy
50. Jogi
51. CKL
52. needsp
53. number9
54. steve jones
55. nuriasanta
56. miksi
57. audiodesign
58. hordmop
59. cjunkk
60. Thermio
61. dex-rex
62. & 63. Claudius J. x2
64. boggy62
65. sck2288
66. rjbaldwin
67. ravid
68. igor
69. neugruen
70. Miclaud
71. Luxury54
72. mjock3
73. JLOP
74. Stixx
75. CeeVee
76. Blitz
77. Spev
78. new2hifi
Old 28th October 2012, 05:46 PM   #1418
List updated, thank you!
L
Contact link for WaveIO USB-to-I2S/SPDIF board.
Daughter card GB list for WaveIO can be found here
Old 28th October 2012, 08:16 PM   #1419
grufti is offline grufti  United States
grufti's Avatar
I just added myself to the spreadsheet for one. Thank you.
Old 2nd November 2012, 12:19 AM   #1420
Sandor is offline Sandor  Italy
Default Connectors for WaveIO headers
Could anyone suggest a connector suitable for attachment to the J9 (external power), J12 (indicator LEDs) and J6 (I2S) headers of the WaveIO board?
A suggestion of a Farnell or RS part number would be geat.
Thanks a lot.
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1372 11th June 2016 07:40 PM
Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface minidsp miniDSP 40 22nd October 2015 08:46 PM
Ultimate USB to I2S interface sampler Digital Source 206 30th January 2012 04:45 PM
Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? cxhawk Digital Source 7 3rd December 2010 03:30 PM
interface I2S with USB mermoz Digital Source 0 21st February 2003 11:34 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
