Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 24th October 2012, 08:44 AM   #1401
Spev is offline Spev  United Kingdom
One doughter board please for me as well:
1. hirez69
2. analog_sa
3. m.massimo
4. ozlegend
5. luisbock
6. vitalica
7. palmito
8. gabanyayaya
9. danny_66
10. shoom
11.12. kp93300 X 2
13. lindamar
14. merlin el mago
15. Reo
16. arkadiush1
17. jmltinc
18. zibra
19. tagheuer
20. hochopeper
21. hacker
22. Bemused
23. vanwykca
24. sandor
25. jrling
26. bismuth
27. necplusultra
28. flocchini
29. ichiban
30. edbk
31. Nikon1975
32. pawlus
33. dubai2000
34. henri47
35. presapian
36. Corpius
37. Ryssen
38. carsten.witt
39. Sidiropa
40. Ryelands
41. krautxy
42. 43. 44. 45. Mats x 4
46. ecchecequa
47. 48. lm1no2 x 2
49. Magsy
50. Jogi
51. CKL
52. needsp
53. number9
54. steve jones
55. nuriasanta
56. miksi
57. audiodesign
58. hordmop
59. cjunkk
60. Thermio
61. dex-rex
62. & 63. Claudius J. x2
64. boggy62
65. sck2288
66. rjbaldwin
67. ravid
68. igor
69. neugruen
70. Miclaud
71. Luxury54
72. mjock3
73. JLOP
74. Stixx
75. CeeVee
76. Blitz
77. Spev
Old 24th October 2012, 09:16 PM   #1402
perra_e is offline perra_e  Sweden
One doughter board please for me too.
I put my name in the WaveIO daughter board list.
--Per
Old 25th October 2012, 08:08 AM   #1403
I have already ordered one (main) board so it seems wise to put myself on this waiting list for the daughter one too
Thanks!
Old 25th October 2012, 08:15 AM   #1404
triode_al's Avatar
Default Why a daughter board.
I have plan to order a standard board. I will go: XMOS --> TDA1541, I/V, buffer. Maybe I will also try PCM56 (with an additional inverter).
But, though I looked through the thread, I cannot find the compelling reason to order a daughter board too.
  • Can someone explain it? What problem does it solve?
DAC TDA1541 S1; MC30-Super --> two stage RIAA; SP-6 clone ; 300B PP: 6N7/ECC82, Metalimphy output.
Old 25th October 2012, 09:59 AM   #1405
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
I thought this GB was for the main board,am I wrong?
Regards Åke
Old 25th October 2012, 10:11 AM   #1406
JLOP is offline JLOP  France
Yes you are, for the main board see WaveIO | Luckit
The projected GB if for a daughter card. Anyhow mainboard works excellently alone.
BR
Old 25th October 2012, 10:15 AM   #1407
Originally Posted by JLOP View Post
Hi all
To connect the Wave IO board to my DAC AD1865 NOS SRPP (which has no connector yet and when Lucian will have done the software update to allow for RightJustified I2S this DAC has ), I am looking for advices :
- what connectors (DEP, 8P8C RJ45, ...) ?
- what cables (shielded, not shielded, CAT5 or 6, flat, ...) ?
Jean-Louis
Hi Guys
I would welcome any advice on my post which was "buried" in the Daughter board pre GB.
Thanks a lot, I could not find much synthesis information on the I2S...
Jean-Louis
Old 25th October 2012, 10:25 AM   #1408
Okay, my english language skills are killing all of us so, let's keep it simple:
1. This GB is for a daughter board (one that will be attached to WaveIO) which wants to improve WaveIO's functionality by adding USB isolation and retiming the I2S signals right before the DAC chip.
2. Usually, all the WaveIO owners can jump in and take benefit of the "numbers" (lower prices for daughter board).
3. If you don't have any WaveIO main board around but you want one then there are two choices for you, as far as I can see now:
a) Sign in into this GB and wait for the WaveIO + daughter bundle to be available and buy all of them at once (you have to wait for some time though!) or
b) go to WaveIO | Luckit and use the shopping cart to order one and later on you can sign in for the daughter GB to take benefit from lower prices.
Daughter board will be integrated into WaveIO boards already sold by sending WaveIO cards back to me, I'll make the necessary hardware + software changes and I'll ship it back to destination.
Hope it helps,
L
Contact form for WaveIO USB-to-I2S interface
Daughter card GB list for WaveIO can be found here
Old 25th October 2012, 11:49 AM   #1409
Ryssen's Avatar
Ok,one mainboard ordered from the site..
However I will remain in the GB.
Regards Åke
Old 25th October 2012, 12:21 PM   #1410
Hi all
Jean-Louis
Sorry for not replying earlier. I forgot to come back.
Basically for each i2s signal you want to take a pair of wires (preferably twisted together to reduce noise picked up OR sheilded with good termination, ie u.fl connector at both dac and waveio end of the cable) from WaveIO to the dac. Ideally the dac will provide a signal+gnd termination for each of the i2s lines. [NOT one gnd pin and a few signal pins scattered around, this means the lines are more susceptible to noise/EMI etc]
At the WaveIO end for i2s output you basically have 2 choices:
1. Non-isolated i2s from u.fl connectors. Take a u.fl cable cut it in half, strip and connect it's sheild to the closest signal ground available on the dac. Strip its internal signal wire and connect to the signal header.
2. Isolated i2s from J6 header. Use IPC cable from header to supply i2s to DAC and provide the required logic voltage (is your dac's i2s input expecting 5V logic or 3v3?) as input to the appropriate pins on the header. Take the pairs of i2s from the cable and connect to DAC. NB You must provide a separate voltage supply here (not the same as the waveio as this will defeat the isolator chip's purpose).
I don't know much about your DAC so would hesitate to suggest which of the above options is best.
Chris
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1303 10th May 2013 05:19 PM
Ultimate USB to I2S interface sampler Digital Source 206 30th January 2012 03:45 PM
Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface minidsp miniDSP 35 13th January 2012 07:02 PM
Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? cxhawk Digital Source 7 3rd December 2010 02:30 PM
interface I2S with USB mermoz Digital Source 0 21st February 2003 10:34 AM
Copyright ©1999-2013 diyAudio
