| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#1381 |
Lifepo4
#1382 |
Hi all
To connect the Wave IO board to my DAC AD1865 NOS SRPP (which has no connector yet and when Lucian will have done the software update to allow for RightJustified I2S this DAC has ), I am looking for advices :- what connectors (DEP, 8P8C RJ45, ...) ? - what cables (shielded, not shielded, CAT5 or 6, flat, ...) ? Thanks Jean-Louis |
#1383 |
I do agree that they are the best battery power technology, but the cells are 6.6v (2S) and we want 5.0VDC for the WaveIO.
So some sort of regulation will be required. The phone charger type LiPOs do output at 5V and would have no charger noise if not plugged into the mains. So convenience factor very high and effectively Plug 'n Play. |
#1384 |
I am connecting the I2s output of the WaveIo board to the I2S input of a Buffalo II DAC. I know that a mod is required to feed the buffalo II with the master clock.
1) What benefit can I expect from feeding the DAC with the WaveIO master clock? 2) Is it necessary to connect the WaveIO master clock to the Buffalo (i.e. do the mod) to have the USB->I2S conversion work in true asynchronous mode ? Thanks a lot. Last edited by Sandor; 20th October 2012 at 09:33 AM. |
#1385 | ||
The mod is required for synchronous mode. |
#1386 | |
#1387 |
is choosing a less facetious title...
it doesnt bypass the pll and go straight to the modulator, nothing changes internally in the ESS, there is no switch, no change in the signal path, its all the same, but if running synchronously it just effectively has nothing to do. the DPLL is 'freewheeling' to use Dustins words. also hochopeper said closer to 100MHz, not actually 100MHz. I guess he just couldnt be bothered typing out the exact numbers of 90.3168Mhz/98.304MHz (<-pretty close to 100MHz dont you think?)
#1388 | |
As I said-the data goes straight to the OSF and DSM without being changed by the ASRC and DPLL. The ESS spec calls for the clock rate to be >192 fs, so for a 192 sample rate that means >36.864 MHz, quite a bit lower than the 100 MHz he mentioned. To meet ESS specs for best operation at up to 192 (the highest rate wave IO allows) 2x clocks would be totally fine: 45.158 and 49.152, not close to 100 MHz at all. That being said, I am running an XMOS based async interface, with 22.579 MHz and 24.576 MHz clocks, the same as the Wave IO's, and it works fine (and sounds better synchronously) with music playback of files at sample rates up to 192. According to ESS, it should sound even better with 2x clocks, I have not heard that yet, but still running the B-II synchronously even with the lower rate clocks sounds better than using the onboard masterclock. Now, if one wants to meet the ESS data sheet, and support sample rates up to 384, then a masterclock "around 100 MHz" would be required (4x rate, or >192*384=>73.728 MHz). But the Wave IO does not support sample rates above 192. My point is, that one should not be discouraged from trying synchronous clocking with the Wave IO's standard clocks, they meet the ESS requirements for rates up 96 KHz, and they will also work fine for rates up to 192 KHz. Listen, and decide for oneself. |
#1389 |
Are we going to have the same discussion on a monthly basis guys? Post#1155 onwards has the same discussion again. Sandor, you might gain something by looking at those posts too.
#1390 |
not going to continue, just correcting the error, which I did, I have no desire to enter into conversation about it, or argue about irrelevent additional details, since it seems not to sink in anyway.
| exaU2I - Multi-Channel Asynchronous USB to I2S Interface | exa065 | exaDevices | 1303 | 10th May 2013 05:19 PM |
| Ultimate USB to I2S interface | sampler | Digital Source | 206 | 30th January 2012 03:45 PM |
| Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface | minidsp | miniDSP | 35 | 13th January 2012 07:02 PM |
| Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? | cxhawk | Digital Source | 7 | 3rd December 2010 02:30 PM |
| interface I2S with USB | mermoz | Digital Source | 0 | 21st February 2003 10:34 AM |
