| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#1061 |
I use mpdPuppy and am very pleased with the SQ.
I chose it because of its ease of install, exceedingly small size and the excellent support by the administrator. Having been a Windows user for a lifetime, I am so pleased that I gave Linux a go and it is well worth it for the SQ improvement it brings. Jonathan |
#1062 |
Wow, very impressive! I wish it were the other way (I2S-->USB) also so that I could use it with a high performance ADC for test and measurement.
#1063 |
Still waiting for info if anyone tried mix WaveIO+Ians FIFO board?
![]() Btw had anyone problems with connectin WaveIo to laptop? It doesnt want to communicate either wirh USB powered or by external PS - theres communicate like "broken USB device" or something similiar. My friend has such problems. Reinstalling USb drivers dont help. USB works properly with pendrive etc. WaveIO works perfect with desktop PC but everytime friend wants to conenct it to laptop there is such error. System is Windows 7 64bit. Any tips? Last edited by zibra; 22nd August 2012 at 08:35 PM. |
#1064 |
Contributor
Im working on the FIFO, had many dramas at home and hope Ian's patience hasn't run out so I can still get my order! Did let him know and he has been very understanding, looking forward to seeing(hearing?) this in action...
#1065 |
Ok guys I have few thoughts to share after testing WaveIO myself and with friend Ill describe main issues:
1. WaveIO seems to NOT bypass windows mixer. Even I have ASIO Luckit driver chosen I still can slide windows volume control to increase/decrease volume. Why? Whats wrong? 2. My friend wasnt able to connect it to laptop, EVEN he used external power supply. After connecting to USB it shows "broken USB device" or something like that. The same settings work perfect at desktop PC. Searching problem in progress. 3. No matter what type of music file you start play device it shows ALWAYS current sample 44100. Whats wrong there, why theres no change when hires file is starting? Where is mistake? All tips are welcome
#1066 | |
#1067 |
I tried JRiver, JPlay, Foobar etc. Regarding problem No. 1 I had it in every occassion and still could use windows mixer slider to operate volume. It happened on ASIO by Luckit and Asio4ALL with all other sound devices off in system or even in BIOS.
Problem No. 2 is investigating as it could be mess with drivers etc. However theres still problem No. 3 described by my friend whos testing now WaveIO. Installing ASIO4ALL helped to change files formats to 48 and 96 but NONE of drivers are able to play 196 kHz files - theres info that type of file is unsupported?? Also Luckit USB Panel looks like inactive and shows constant 44.1 stream format. I cannot see these problem right now as I dont have WaveIO here but first problem I experienced by myself. Using Windows 7 64 bit both me myself and friend. |
#1068 | |
Note, The Wave IO is no longer bus powered and has it's own 5V supply, This also brought a surprising improvement. Best Regards, James. Last edited by JamesHill; 24th August 2012 at 12:18 PM. |
#1069 | |
Best Regards, James. |
#1070 |
Sorry for the double post, not sure how that happened!
| exaU2I - Multi-Channel Asynchronous USB to I2S Interface | exa065 | exaDevices | 1304 | 23rd May 2013 03:43 PM |
| Ultimate USB to I2S interface | sampler | Digital Source | 206 | 30th January 2012 03:45 PM |
| Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface | minidsp | miniDSP | 35 | 13th January 2012 07:02 PM |
| Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? | cxhawk | Digital Source | 7 | 3rd December 2010 02:30 PM |
| interface I2S with USB | mermoz | Digital Source | 0 | 21st February 2003 10:34 AM |
