Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 11th May 2011, 12:16 PM   #1
kenp3 is offline kenp3  Canada
Default Arcam alpha 5 problem
I was able to get one of these cheap, as in free. The previous owner stated that it didn't work at all.
Took it apart and there were bad solder joints where the plug goes in, it now reads all cd's but the drawer mechanism doesn't work. Started poking around and found a resistor that was burnt out for the drawer mechanism, once that was changed the drawer worked but all the time as in drawer advances and and motor doesn't disengage. Wondering if anyone has had similar experience with this player and what they did.
Thanks in advance.
Old 13th May 2011, 02:43 PM   #2
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Problems like this are usually a limit switch gone faulty.
Arcam are usually very heplful, particularly with diagrams.
Also try doing a forum search for similar models.
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Arcam Alpha 9 problem Colin151 Solid State 14 20th January 2011 09:54 PM
Arcam Alpha 5 CD - playback problem szawszaq Digital Source 4 30th October 2010 10:12 AM
Arcam Alpha 5 Problem Grizzard Solid State 6 24th August 2010 05:46 AM
Problem with Arcam Alpha 7 CDP Tripmaster Digital Source 1 9th April 2009 07:04 PM
Arcam Alpha 8R problem goodlife Solid State 2 7th July 2006 08:16 PM
Page generated in 0.05637 seconds (71.39% PHP - 28.61% MySQL) with 10 queries
