| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
HI Everybody,
i just bought a Krell studio DA converter I am REALLY surprised how good it sounds.i have tried MANY--MANY unit and this one really is surprising to me. Few things i want to ask : 1-Can someone decribe what technologie is used ? 2-Does someone have the schematics ? 3-I would like to "clean" the unit . i mean by that can i would like to upgrade/clean the cap . 4- Can someome help me with what could be uprgaded ? 5- Is there any possibility to uprde the unit ? if yes how ? 6- By Upgrading i mean the high "seems " a bit dry ….a bit i mean….dry caps? 7- is there a way to try another output stage ? 8- and ….finally if anyone has info reagarding the reference64 model compare to this one i would be more than happy to hear story or tech things about it. the low end of the unit is fantastic.the top is a "little"bit dry.now if by a better power supply or caps or other thing ...or even different chip i could do improvement starting with that base... thanks for all your advice !! Phil |
#2 |
See some motorola DSPs i think; custom digital filter. DACs would be on the right pcb at the bottom (BB or AD). Large analog section.
Wonder if you even should touch it...
GuidoB |
#3 |
first phase i wanted to be sure to be at the max...and must dry up with the time no ?
#4 |
nobody to help me on this ?
#5 |
Hello,
This Krell DAC is a complex machine, I have some experiences with Wadia X32 and X64. The first point is the input circuit which may have one or more slow logic gates ( HCU). See the doc on TVC Audio- Audio Numeric Performance The second point is the VCXO that is very important but very more complex to change. TVC Audio- Wadia X64 You must do the jitter measures on the two part before the modifications and redo the measures after . Rémi |
#6 |
Hello,
#7 | |
here additional URLs of this device: Krell Studio DAC ! - ¶ú»úÒôÏìÑÐÌÖ»á - ¶ú»ú¾ãÀÖ²¿ÂÛ̳ ¶ú»ú,¶úÈû,¶ú·Å,¶ú»úÂÛ̳,ÒôÀÖ,ÒôÏì - ¶ú»ú¾ãÀÖ²¿ ÍËÉÕ³ö KRELL STUDIO DAC ¶ú»ú´ó¼Ò̳ È«Çò×î´óÖÐÎĶú»úÂÛ̳ I want also to have a schematic. |
#8 |
hi
thanks for the advice...i am going to start |
#9 |
for more information arround lifetime from caps, use by Google the term "bad caps" and you will get several proposals, e. g.:
Best electrolytic capacitors Badcaps Forums - Salvation For Your Hardware! What happens to cheap Caps after 30 years in a hot console? - Badcaps Forums Cyrus two - non polar cap Capacitor Brand Voodoo - Let's clear the air Krell KSA-250 failure (pic from post #4) Last edited by tiefbassuebertr; 11th May 2011 at 08:18 AM. |
#10 |
I have kreel studio also, I have a problem with my DAC. which can not lock. I try to replace him but VCXO frequency is 3400 MHz weird. hard to be right. friend said that this jitter problem. but I've unsolder jitter but with the Krell in the cast. circuit can not be viewed. complex digital PCB pathway consists of three lines, really complicated .......
I want to fix it because it couples with the cd transport Krell MD-1 |
| H/K HD710 tweaking advice | Mr.Mekulic | Digital Source | 4 | 7th December 2011 02:08 PM |
| Modding a Denon da-500. This noob needs some advice. | SuperKris | Digital Source | 30 | 9th November 2011 06:57 PM |
| Audiophile transformer for Krell DAC-studio | gto127 | Digital Source | 5 | 20th January 2008 08:04 PM |
| Leach or Krell for studio monitoring? | rotation | Solid State | 18 | 17th August 2006 06:26 AM |
| krell studio 2 | ben goh | Digital Source | 0 | 1st March 2003 02:13 AM |
| Page generated in 0.11129 seconds (80.07% PHP - 19.93% MySQL) with 11 queries |
