Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 4th May 2011, 10:41 AM   #1
Default Denon DCD 595
Hello All,
I recently received a Musical Fidelity DAC and I am looking for a way to get Digital Signal from my Denon DCD 595. Can anyone help me please? Has anyone ever done it? Any help appreciated.
PS I have the schematics if this helps at all....
Thank you all in advance!
Old 4th May 2011, 03:48 PM   #2
guytou is offline guytou  France
hello ,on DCD595 the decoder is CXD2500BQ , on pin 60 of that chip you have an SPDIF-out , and you have to enable the SPIF-out by linking pin59 to +5V .
hope this helps,
"celui qui est parti de rien pour arriver à pas grand chose ,n'a de merci à dire à personne "-Pierre Dac
Old 4th May 2011, 08:45 PM   #3
guytou Hi!
thank you very much for the reply! Your help is appreciated!
I removed the JV402 bridge and added a bridge to JV 401 (in order to supply with +5V DC). I measured it and +5V DC is there.
I tried to connect the DAC I have (Musical Fidelity) to pin 60 (with a 75ohm resistor), but it does not work... Should it work? Am I doing something wrong?
The next step would be to add the circuit that is missing from the DCD 595? I mean IC701, BT300, resistors capacitors etc? I have the service manual (it is the same with DCD 695 that has a digital coaxial out) but I am not so experienced... so I need more help...
Thank you very much in advance!
Kind regards from Greece.
Old 4th May 2011, 09:34 PM   #4
hi, you well removed JV402 to lift MD2 from ground. Unfortunately ,my SM is in german but from memory pin59,MD2 allows to enable Dout, pin60 when high , ie +5V.
You could have a look with a scope on pin 60 to see what happens .
Old 4th May 2011, 09:43 PM   #5
the circuitry behind is so buffering , so you would find something of interest on pin60
Old 5th May 2011, 07:19 AM   #6
Hi guytou,
It looks something like this... I will try to find tha components and fix all the circuit. It seems that it is very difficult to find the PT300... it is a pulse trans. I hope you can see the attachment.
kind regards and thanks again for your help.
Old 5th May 2011, 11:26 AM   #7
hi ,I have the service manual too . On that sheme , IC 7018 and PT 300 are not mandatory , the signal is already present as is at pin60 . in case your DAC dosn't lock because some DC , try to insert a 1nF capacitor in serie (between pin60 and the DAC).
Old 5th May 2011, 12:12 PM   #8
I will try this evening and let you know... I can not thank you enough for your help. I have the DAC but unfortunately, at the moment, no budget for a decent source... so I use a cheap DVD player as a source with a great DAC.... I imagine that this will be a superb upgrade.
kind regards
Old 5th May 2011, 12:40 PM   #9
concerning the buffering circuitry (Ic7018 and PT300), try a search on this forum with "SPDIF out" , for exemple .you'll find a lot of hints .
Old 5th May 2011, 12:45 PM   #10
oooops ,cross message . oh , DVD player could be a decent transport . For your Denon , it would work as is , I hope it will in your case
Need Help on Denon DCD-1015G latitude Digital Source 3 30th April 2011 01:07 PM
Denon DCD-1450 error0 Digital Source 4 30th July 2009 08:37 AM
Denon DCD-3000 or DCD-2700 johngo Digital Source 0 26th December 2005 09:09 PM
denon dcd 520 crippledchicken Digital Source 3 9th September 2004 05:54 PM
Denon DCD 615 Mazta Digital Source 0 27th May 2003 10:22 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
