| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I've had a problem with a modification to my Transporter where an upgraded transformer came loose in shipping and broke one of the 30 pin connectors on the front PCB behind the display and damaged the ribbon cable. I was able to get new 8" ribbon cables from Molex as part of a sample request, but the connectors I have ordered are the wrong ones and these parts are apparently very hard to locate. I'm pretty sure the pitch is 0.5mm, but this new connector (Molex part # 52559-3052) isn't seating properly in place of the old one. So if anyone can tell me the proper part # for the 30 pin SMD connector on the front PCB (which is also the same one as on the main PCB board) I'd be forever grateful. Thanks so much - Phil |
#2 |
Are there ANY markings or numbers/letters on the original ones?
A picture of it would be extremely helpful. Have you tried looking through all of the similar connectors at places like mouser.com? Or go to google.com and do a search for "30 pin SMD connector 0.5mm" and then click on "Images". If you know it's by Molex, then add that to the search string. |
#3 |
Hi Gootee,
Here's a picture of the unbroken one. I have looked through all of the parts and I thought this one was the correct one, but apparently the pitch is slightly off but the other nearest ones are 1mm which are twice the size. I think the connector Logitech used may now be discontinued, I'm not sure. The problem is they only show rough drawings on Mouser and Digikey, as well as Molex, and the PDF/CAD files aren't showing me what I need to know apparently. The connector must be a Molex one because it mates with their FFC/FPC ribbon cables. I believe the only way someone will know this part number is if they have actually ordered one in the past and used it for this purpose, or were able to get one from Logitech and/or work for Logitech.
#4 |
This might sound like a bodge but it works unless your connector is too damaged of course. This connector is a very common part to break even when just unclipping it.
Push the ribbon cable into the socket and wedge it with some thin plastic. Test the unit to make sure the display etc works perfectly. If not try re-seating the cable. Once you are happy with it hot glue the connector so that it can't pop out. Brent |
#5 |
Hi rowemeister,
Yes, that was something we were thinking about but the connector was pretty badly mangled so it's been removed. With all the bad luck I've had with audio equipment in the past year and a half I just didn't think we should chance it. And like you mentioned, the connector is a common part to break because it's cheap garbage. It's rated at 20 maximum mating cycles, and the cables also have a way of coming unseated on their own without any help from you whatsoever. Slim Devices should have used something much better. |
| iPod Touch 4G 30-pin Connector Schematic | undertone | Digital Line Level | 5 | 21st March 2011 01:33 PM |
| PCB to PCB 5 pin connector | wigginjs | Parts | 4 | 24th October 2008 08:01 PM |
| what part can take the place of ST part VB408B completely | peterchen88 | Parts | 0 | 8th September 2007 05:45 AM |
| part# for spare part for CDM-1 wanted | joe | Digital Source | 5 | 20th March 2007 07:59 AM |
| Looking to replace Logitech Z680 part. | Sa3atsky | Parts | 6 | 30th May 2005 09:25 PM |
| Page generated in 0.11416 seconds (72.18% PHP - 27.82% MySQL) with 10 queries |
