Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 26th April 2011, 06:02 PM   #1
grahamfocal's Avatar
Default replacing 47mf for 33mf caps...good idea
I do appreciate that changing capacitor values is not really the best idea.
I have a new CD player (well second hand over 10 years old) and a load of Slilmic IIs, trouble is that there are a lot of 47mf 25volts in the CD player, but I only have 33mf 25volts.
Will it hurt? basically, or is it best to make sure I buy the correct ones.
I've got an idea--an idea so smart that my head would explode if I even began to know what I'm talking about
Old 26th April 2011, 06:13 PM   #2
picowallspeaker's Avatar
I haven't done such mods , but I see that commonly used values can be in the order of a magnitude less
Old 26th April 2011, 06:17 PM   #3
don't worry too much, although going up in capacitance would be better the improvement will probably still be noticeable ...
Old 26th April 2011, 06:51 PM   #4
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
As you may have read, some caps are sensitive to value.
I'm thinking in the servo section of players with the Philips cdm1/2/4
Remember, do mods one at a time. Then you know where to look if it stops working.
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 26th April 2011, 06:53 PM   #5
If you had an esr tester you'd know if the new parts were better or worse than the old ones. As is there's no way of telling if you're accomplishing anything. Just being old doesn't mean they're bad in any way. OTOH, if they're substandard after a year, they need to be replaced.
I used to be an audiophool like you but then I took an arrow to the knee.
Old 26th April 2011, 07:36 PM   #6
Andy
yea as you probably remember, you helped me a lot on my Orelle CD100 along with Mooly this does indeed have a CDM4-19. I have upgraded the OPAMPS already, with a good outcome (the musical FID CD1 even had the chip holders already installed) had the whole payer apart to count and note the caps. Lots of 47s, so might just (as I am no expert) get the correct ones, the 33s will probably come in handy. Thanks all.
Old 27th April 2011, 09:43 AM   #7
amc184 is offline amc184  New Zealand
amc184's Avatar
It depends on what the capacitor is doing. If you're talking about the 47uF capacitors that many manufacturers used as local decoupling for every IC, then yes, no problem, anything between about 22 and 220uF will do the job. However, in some rare circumstances it may cause a problem. It's unlikely though, electrolytic capacitors are very poorly toleranced, so are generally not used in a situation where capacitance value is so critical that a 47uF unit would work yet a 33uF unit would not.
Inside Classic Audio, my blog on repairs, modifications and anything else to do with audio.
Old 27th April 2011, 12:23 PM   #8
Many thanks for that.
Old 27th April 2011, 06:10 PM   #9
Fidelity Audio's Avatar
I usually find going up one or two levels of uF in capacitance helps with bass weight and smoothness. Going lower with the uF can tend to lean out the sound pushing it a little towards upper mid dominance aka Naim etc. Too high a uF can make the bass over bloated and ploddy.
Again this all depends what voltage rails you are swapping capacitors on, generally digital circuit rails prefer larger uF capacitors where analogue rails can tend to get away with lower uF.
Not counting ESR and ripple there are lots of ifs and buts.
Brent
FS: Audio Note 0.47mf Copper Paper in oil Caps jdeitch11 Swap Meet 1 21st March 2011 03:20 AM
Replacing multi-section caps with multiple caps? Sir Trefor Tubes / Valves 1 29th May 2007 10:17 PM
motor run caps in the output? good or bad idea? jarthel Tubes / Valves 36 1st November 2006 06:47 PM
Replacing ceramic disc caps with silver mica caps? G Solid State 5 18th November 2002 01:02 PM
Page generated in 0.09836 seconds (80.22% PHP - 19.78% MySQL) with 10 queries
