| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Banned
Has anybody modified (or has plans to modify) a Proceed CDD (or similar transport) to support the I2S-interface standard. The transport supports SPDIF and AES/EBU and I expect that the I2S interface wil improve the output of the Proceed DAC (or of cause other DAC), assumed it has the I2S interface.
#2 |
Banned
I performed some investigation by opening the CDD and on the internet, with the following results:
The Proceed CDD has a Philips CDM12-IND drive inside. There are 5-power regulators , three 7805CT one 7809 and one 7808. They all use low priced caps and resistors (as I can see). I havent yet ‘found out which parts of the design each regulatore is linked to.I also couldn’t trace the crystal frequency, also I know the digital output is buffered and re-clocked. On the internet I found that the CDM12-IND drive is compatible with the Philips CD-PRO (http://www.daisy-laser.com/cdpro.htm), which supports I2S-output. So does this mean I can conclude the CDM12-IND also supports the I2S-standard, so yes I can’t find anything on the web about the pin-layout of the connectors on the CDM12 module or the CD-Pro module. Besides the I2S-interface that I would like to incorporate in the CDD, I have the idea to improve the Power supplies, although I don’t yet know which one to start and what design to use. I do know I it should be clean (especially no high frequency noise). Any suggestions/help |
#3 |
Hi Calimero...
I have sime question for my CDM12.1 from steinmusic...Where to find I2S... after some search on the web I found this page http://www.geocities.com/koalavilla/audio_transport.htm where they say that I2S is taken directli from SAA7310 ... here is SAA7310 data sheet http://members.xoom.virgilio.it/hi_fi/q7310.htm from what I can see that I2S should be on pin 2,3,4 (DAAB,CLAB,WSAB / data,clock,word select ), but I am not shure...I'am not EE... Maybe yours CDM12 have sime IC on board and you can use this information ... Regards Josip |
| Proceed PCD2 | QSerraTico_Tico | Digital Source | 19 | 30th January 2012 09:55 AM |
| how to proceed | trifidmaster | Pass Labs | 42 | 26th October 2010 03:44 PM |
| proceed dap dac | little blue | Digital Source | 0 | 18th September 2007 03:41 PM |
| Proceed Pav Schematic | wayle45 | Solid State | 6 | 5th February 2007 03:07 PM |
| Proceed PDT-3 | Elso Kwak | Digital Source | 2 | 18th February 2003 02:22 PM |
| Page generated in 0.07180 seconds (69.53% PHP - 30.47% MySQL) with 10 queries |
