Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 12th April 2011, 09:15 PM   #1
Default Philips CD960 CDM1 does not read last tracks a cd's
My Philips CD960 with a CDM1 laser unit has problems reading the last +/- quarter of cd's. Playing to the end gets further than skipping tracks to the end.
Anyone any idea what could be the cause?
Thanks a lot,
Vincent
Old 12th April 2011, 09:25 PM   #2
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Does the mechanism track freely across the whole range ?
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 12th April 2011, 09:54 PM   #3
UV101 is offline UV101  England
UV101's Avatar
The 5 blue philips caps on the CDM pcb will be tired now. They are known to cause reading issues in general although they normally effect all not just the last 1/4.
You could also check the motor spindle height adjuster, poss wants to be a tiny fraction wound in after this time, that has caused tracking problems for me in the past.
As Andy says, check the swing arm can move freely across the whole disc before you start pulling to many parts out!
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
Restek Fantasy, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 13th April 2011, 09:41 PM   #4
Thanks for the reply's.
I put the player in service position 0.
Using the >> and << buttons, the arm swings without any problem from most inner to most outer position.
I do not exactly understand where to find the 5 caps you mentione.
Picture attached. Could you point it out?
I'll now go searching for the motor spindle height adjuster
Old 13th April 2011, 10:26 PM   #5
UV101's Avatar
looks like 4 of the 5 have been replaced already. Originally, they would have all been like the single light blue radial. I think they are philips branded 33uF? The 4 darker colour upright caps would have replaced the light blue type.
The spindle height adjuster is torx head by the "G" sticker. Make sure you mark the screw so you can set it back to the original position. I would start by winding it in about 8th of a turn. The screw is nylon and may have worn over time allowing the spindle height to have dropped slightly.
Old 13th April 2011, 10:30 PM   #6
UV101's Avatar
This is my mech. I replaced the caps on mine with Oscon 33uF/16v
Cdm1 mkii
Help with Philips CD960 muizel Digital Source 11 1st May 2012 12:24 AM
nakamichi mf-51 doesnt read recorded cd's anton-sa Car Audio 3 28th August 2008 08:56 PM
Philips CD960 diyman Digital Source 0 1st November 2005 01:50 PM
Revox B226 won't read CD's Zombie Digital Source 4 21st January 2004 09:39 AM
Page generated in 0.09249 seconds (76.31% PHP - 23.69% MySQL) with 11 queries
