Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 6th August 2003, 04:58 AM   #1
Default TDA1541A non/os harsh!!!
Denon DCD S10 (2 AD8620, 4 opa627BP, 8 opa637BP, Elso kwak clock 6)
Rotel 855 (non/os, 2 AD8620 ,Elso kwak 7)
Magnavox CD650(non/os, 2 AD8620, TDA1541A S1)
When I listen some violin CD, I fell the Rotel 855 and Magnavox CD650 are sweeter than the Denon DCD S10, but listen femal voice the Denon DCD S10 is less harsh than the Rotel 855 and Magnavox CD650. Will the TDA1543 nos/os be less harsh than TDA1541A nos/os?
Old 6th August 2003, 06:21 AM   #2
diyAudio Moderator Emeritus
jean-paul's Avatar
Did you change the analog filter when you made the cdplayer non os ?
It's only audio
Old 6th August 2003, 07:11 AM   #3
I just changed the two NE5532s on non/os Rotel 855 and Magnavox CD650. Should I build a new I/V stage?
Old 6th August 2003, 04:38 PM   #4
I'd reconsider a new analog filter
regards
Guido Tent
www.Tentlabs.com
Old 6th August 2003, 06:22 PM   #5
jean-paul's Avatar
When you make a TDA15xx cdplayer non os the analog filter has to be recalculated. Use the Search function for more info, there are threads about the subject. The harshness comes very likely from the unchanged filters, it has nothing to do with the used chip.
When you're brave please listen to the cdplayers once without analog filtering. So use the opamps but remove filter components. When the harshness is gone you have an indication you're on the right path.
Warning: I wouldn't recommend to listen without analog filtering permanently. There could be ( there are in fact ) some RF components in the output signal that might disturb your amp. That being said I can tell I use only 6 dB/oct filtering with TDA1543 non os DAC's and I get away with it. Although I haven't built it, the discrete outputstage Rbroer designed looks promising and it is simple to build. Should be better than a opamp stage anyway.
It's only audio
Old 6th August 2003, 07:54 PM   #6
Banned
Send a message via Yahoo to Elso Kwak
Question Crossover point?
Hi Jean-Paul,
What is the crossoverpoint (-3dB) of your 6dB/octave filter?
Old 6th August 2003, 08:07 PM   #7
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
That's being said, I'm perfectly happy without any filtering at all in my NOS TDA1543 DAC. There is no sign of harshness or fatiguing or irritation, totally smooth highs.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 6th August 2003, 08:10 PM   #8
Banned
Exclamation Re: TDA1541A non/os harsh!!!
Hi Mikeliu,
I was never able to elicit any harsh sounds from the TDA1541! In fact I found it too mellow, "polite", uninvolving....
The TDA1541 does not sound harsh, NON-OS, in my Phlips CD-650 with orginal analog filtering still implemented, that is for oversampling.
If you find the TDA1541 harsh you will find the TDA1543 unbearable.......
I am not familiar with the AD8620 yet. May I suggest using the OPA2604 instead? Especially as a IV-converter it can't be beaten I think. I tried a lot of IC's !
Just a thought:
You did lower the supply voltage to +/- 12V for the AD8620 in these players?
Old 6th August 2003, 08:23 PM   #9
jean-paul's Avatar
Then you should try AD8620 I think. Please don't suggest other chips when you don't know the used type. Leave it where it is Mikeliu, AD8620 is very good.
Just a thought:
Very good point as most cdplayers use +/- 15 V which is too much for AD8620. I assume you did correct the supply voltages otherwise you probably have the main reason for the nasty sound. Nevertheless I think it is better to recalculate the analog filter ( or leave it out when you like to live dangerous ).
Elso, one DAC has a filter with -3 dB at 48 kHz just to prevent very high frequencies from going in my amp. Never bothered to implement sinx/x filtering. I don't have any problem with the high roll off.
To be honest, most of my TDA1543 dac's didn't have filtering at all. Maybe I put 2 caps at the output of that series just for peace of mind
It's only audio
Old 6th August 2003, 08:35 PM   #10
Banned
Angry IV-converter chip
Then you should try AD8620 I think. Don't suggest other chips when you don't know the used type. Leave it where it is Mikeliu.
Jean-Paul,
I suggest the chip I have very good results with
harsh query steve04 Multi-Way 2 9th December 2008 12:25 PM
db6501 too harsh is there anythng I can do? Yanibm1 Car Audio 1 3rd March 2008 05:43 AM
nad 3020i harsh sound mad_z Solid State 14 24th August 2007 04:45 PM
Harsh sounding amp zeus_threat Solid State 45 9th April 2006 04:30 PM
fe167 harsh tenderland Full Range 33 15th February 2005 02:02 AM
Page generated in 0.14199 seconds (83.10% PHP - 16.90% MySQL) with 10 queries
