Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 2nd April 2011, 11:36 PM   #1
Default ANOTHER CHEAP CLOCK ON EBAY
Hi all as any one tried this clock just wondered if there any good as i need one for my marrantz 67 Good for CD player Active Clock Plate 16.9344MHZ on eBay (end time 09-Apr-11 16:17:38 BST)
Old 3rd April 2011, 01:43 AM   #2
erin is online now erin  Australia
I'm far from an expert, but from reading on the topic, what I took away from reading is that its the smoothness of the power supply that supplies the clock, which is one of the biggest factors in the quality and accuracy of the clock. Simply using a 1PPM TCXO crystal is not going to give you better sound. Look at this clock and see how there is a big effort to use various capacitors and inductors to give a smooth power supply EZ Ultimate Clock System | Diy HiFi Supply and it includes its own dedicated transformer power supply as well!
Having said that I a while ago tried a different but a little better designed cheap clock upgrade kit from ebay, and at the time I thought it made a difference, but better or just different, I was never sure, any improvement was probably placebo effect.
Perhaps you are better to use some better power supply capacitors that supply the existing clock in your player?
Others may have an opinion?
Old 3rd April 2011, 02:07 AM   #3
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
I just wonder how you know you need a clock? Bolting on an external clock like this might not lead to lower jitter because with an externally wired clock you've got common impedances in the ground wires - the clock isn't differential. With the supply current going through the ground wire as well as the ground being used as signal reference there's noise coupling into the clock signal. Shorter wires are the solution but that's impossible with such an after-market mod. If higher jitter is the result, no doubt the placebo effect will more than compensate for this
I agree with you erin - power supplies to clocks are crucial.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen
Old 3rd April 2011, 10:56 AM   #4
Hi thanks for replys i did read some were that the power supply for the clock is very important.Reason i thought about a clock in the player is because in the marrantz cd 63 and 67 mods list it says its one the important upgrades to do the player already has biger better quality caps upgraded opamps and another exsternal power supply
Old 3rd April 2011, 07:11 PM   #5
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
The internal clock on the CD67 / CD63 is not very good.
Almost any aftermarket clock will be better than the standard.
The clock mentioned above is pretty basic and does not appear to heve any supply regulation.
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 3rd April 2011, 08:16 PM   #6
Andy
Hi andy would you not bother with that clock then. Can you recomend another cheap one if this is not any good. thanks steve
Old 3rd April 2011, 08:37 PM   #7
anatech is offline anatech  Canada
anatech's Avatar
The only spec that is important for the clock in a CD player is short term stability. Crystal oscillators happen to be very good in this regard. Therefore, about the only thing I can think of that might mess things up is a noisy power supply. If the supply is a mess, then build a crystal oscillator and use a buffer to drive the clock input of the IC and this is the best things will get.
You can also purchase clocks for the CD player that are discipled by the GPS satellite network. Overkill, but perfect for the audiophile braggart.
Remember, the only important specs are jitter and short term stability. These two terms overlap somewhat. Anything else is a waste of money. Don't buy cheap crystals!
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 3rd April 2011, 08:51 PM   #8
-Chris
Hi chris thanks for reply im fairly new to the diy hifi game and dont want to spend too much money on a clock as i dont have much confidence in my work yet
Old 3rd April 2011, 09:01 PM   #9
anatech's Avatar
Hi bull041161,
Sounds good.
All you need to do is use common sense. Ask questions and do good, clean work. I'd advise against doing anything you can't come back from (permanent changes).
Most of high end tweaks are grabs for your money, except when a real fault or short coming is being addressed. Just pay attention to the basics of how things work. Also, a CD player is not a turntable. Belt drive and "stable platter" offerings are stupid. A CD must be able to change rotational speed quickly. It ain't a turntable!
-Chris
Old 3rd April 2011, 10:34 PM   #10
Hi bull041161,
Sounds good.
-Chris
Hi chris yes i agree im not going to tackle any thing too difficult. I have done the hdam by pass uprated some caps but i have just added some those fantastic screned ha op amps and thay made a real big improvement in sound
Anyone tried this cheap clock....... nad Digital Source 6 7th April 2010 04:50 PM
cheap ebay dac's valo Digital Source 1 11th December 2008 09:57 PM
I used a cheap cheap clock Sunsun22 Digital Source 33 7th April 2006 02:44 PM
Audiocom low jitter clock on ebay David Gatti Digital Source 0 1st May 2004 07:40 AM
Page generated in 0.11449 seconds (79.63% PHP - 20.37% MySQL) with 10 queries
