DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 99 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 21st December 2011, 04:11 PM   #981
pchw is offline pchw  United States
Originally Posted by buzzforb View Post
I will be ordering one of these today, and was wondering if there is a link to the post with suggested mods?
I started from this post. I am in the process of stripping down the assembled AK4396 board and assembling an AK4393 kit.
If you haven't purchased, buy the kit!! I already lifted a few pads due to the crazy amount solder used The AK4396 will be used for direct out, and the AK4393 will be with opamp. Still waiting for the parts to come.
- Fred -
Old 22nd December 2011, 01:44 PM   #982
Hello I need some advices .
I would like to replace the CS8416 by a DIR 9001
If you look at the picture attached,i don't find how to connect the SMUTE ( Pin 8) and the DFSO ( Pin 9 ) with the DIR 9001 .
if you have an idea , let me know
Serge
Old 22nd December 2011, 04:24 PM   #983
Just curious: direct out how?
Have you already tried it?
Old 22nd December 2011, 05:49 PM   #984
Direct out might be the wrong terminology.
What I meant was to take the signal directly from the dac and feed that
into either a cap, or transformer, or nothing at all into the preamp.
There were some discussions in previous posts of various approaches. This is
just to satisfy my curiosity of how each approach will work out.
- Fred -
Old 23rd December 2011, 07:17 AM   #985
erin is offline erin  Australia
Certainly try things for yourself as its the only way to learn, but I have a strong suspicion that this output stage from this earlier post is the way to go...DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532
Old 23rd December 2011, 07:19 AM   #986
WM8805 is the only receiver worth "upgrading" to. IMO not worth mucking around with a DIR9001, although the DIR9001 is better than CS8414.
Old 23rd December 2011, 07:53 AM   #987
When this output stage is running correctly ,this solution is not so bad !!
Actually I have some problems , i have checked different power supply values ( +/- 15v , +/- 20v ) .......... and the stage is not stable
This output stage is followed by an Headphone amp ( WOO6 ) ,when the potentiometer of the WOO6 is on the left ( No sound ) the power supply values are very strange .I have not the good values less than the settings .
When the potentiometer of the WOO6 is on the right ( max sound ) the power supply values are good !!
Thanks for your advices
Serge
Old 23rd December 2011, 08:59 AM   #988
Try putting a 1K resistor in series before the 1M gate stopper. Perhaps also try a 300 ohm on the output. Perhaps you are getting oscillation?
eg. DAC > 1K > Gate stopper > FET > FET > 300R > headphone amp
Old 23rd December 2011, 05:58 PM   #989
Thanks for your advices .With a 300 Ohm on the output it's stable .But no sound
The AK4396 is dead
The 5v on the AK =0 v .The power supply is good when i disconnect the 5v wire from the AK .I have 5v on the power supply .
.......I am a big STUPIDO
Serge
Old 23rd December 2011, 09:50 PM   #990
F1 FAN is offline F1 FAN  Canada
The AK4396 is dead
Serge
Check for a shorted capacitor or solder bridge in that 5volt line.
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
Copyright 1999-2017 diyAudio
