Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 11th December 2011, 11:49 PM   #951
Greg Erskine's Avatar
Originally Posted by pchw View Post
Hi Greg,
The way I connected is the same as Erin's diagram in DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532. I used to wires to connect one wiring section of the {12-0}-12 to the second AC connector.
Thanks!!
Did you add the link under the PCB when you used a single transformer?
Greg Erskine
Old 12th December 2011, 12:00 AM   #952
pchw is offline pchw  United States
Hi Greg,
See the attached picture of how I connected to the 2nd AC connector with one transformer. I didn't have any other connection under the PCB.
Thanks!!
- Fred -
Old 12th December 2011, 12:05 AM   #953
F1 FAN is offline F1 FAN  Canada
The second bridge rectifier(in digital sec.)is not needed,simply adding a jumper at the alotted space on the bottom of PC Board will feed the positive DC voltage to the digital section.
Old 12th December 2011, 12:15 AM   #954
Totally understood, I could run a wire from the +ve DC of the 1st bridge which is probably what Greg meant either.
It was more like the stubborn side of me trying to figure out why the configuration flowing around, as posted by Erin, would work for others but not me
Thanks,
- Fred -
Old 12th December 2011, 02:07 AM   #955
erin is offline erin  Australia
My diagram was incorrect. Oops, sorry. Embarrassing. Perhaps the moderators could remove the original diagram so others don't make that mistake.
Old 12th December 2011, 02:16 AM   #956
Originally Posted by erin View Post
Was my cruel and unusual diagram incorrect?
It didn't work for me that way as you can see that's what I did at first.
If you follow the schematic, this wiring will effective connect the ground to one side of the AC input of the +3.3 connector.
Thanks,
- Fred -
Old 12th December 2011, 02:19 AM   #957
Yes. I see the problem now.
Old 12th December 2011, 02:35 AM   #958
Just in case there is still confusion to the link I was referring to, here is a picture, link in red.
And yes, only wire to 15-0-15 terminals.
Greg Erskine
Old 12th December 2011, 05:23 AM   #959
That's what I ended up doing after I saw yours and F1's reply.
Thanks for the hint!! Now, its time to make LPF correction and
other mods. Yes, I have ordered the parts :-)
- Fred -
Old 12th December 2011, 09:58 AM   #960
For the fun i try this output stage .
There is no output capacitor because there is one on my WA6 input ( Headphone tube amp ) .
My conclusions today .
Better than the OP ,better than the direct output ( Just a serial capa ,or the RC filter ) ...
Serge
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
