| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#81 | |
I suggest you put 470uf oscon. But I guess any value oscon you have will be OK. Be sure to give it 22000uf on all rails! Last edited by erin; 17th May 2011 at 12:54 PM. |
#82 |
Couple of my friends have Buffalo II DAC that uses ESS chip ... although I havent heard it myself Ive heard good things about it... but it depends on what system you plug it in.
I also prefer analog/less detail to digititis/fireworks detail , anytime. Will do, i have 400.000uF in my amp ... Im sure it wont mind if I borrow some ![]() Peace! |
#83 | |
400,000uf!! ROCK ON
#84 |
Hi, I've just ordered this kit, from what I hear, it's well worth taking the plunge.
Now this may be a stupid question (ahem, newbie...), but could it be converted to tube output? I've been toying with the idea building a tube DAC for a while... Thanks. |
#85 |
Hi there.
Which kind of Sanyo Oscon are recommended for this DAC please? Just ordered one too - will be fun to compare that with my Gigaworks 24/192 DAC ![]() - John |
#86 |
#87 | |
NCC PSA or PSC are quite good, and if you are on a budget, they would be my second choice of capacitor. With OS-CON SEPC being my first choice. The NCC PSA gives a bit of a fuzzy sound in the mid bass region, and a slightly slower overall sound. The SEPC is lighning fast and crystal clear across all frequencies. The NCC PSA is still a large step up in performance from a regular electrolytic capacitor. |
#88 |
Many thanks for that Erin - very helpful indeed!
These look like the correct items (much cheaper than I thought too... hope they're not fake!): 4pcs 16V 470UF SANYO SEPC Aluminum solid Capacitor | eBay UK - John |
#89 | |
#90 |
He will supply long legs if you ask, but can we be sure they're a genuine Sanyo component?
| AK4393 burn... | CIMONE | Digital Line Level | 5 | 24th June 2011 02:12 PM |
| AK4393 to CS4223? | CIMONE | Digital Line Level | 0 | 13th December 2009 02:30 PM |
| AK4393 Serial Configuration Problem | Aoxomox | Digital Line Level | 0 | 20th March 2009 05:25 PM |
| AK4393, CS8413 and CS8414 Data Sheets | Blue_Max | Digital Source | 0 | 23rd December 2004 01:37 PM |
