DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 69 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 17th September 2011, 11:29 PM   #681
F1 FAN is offline F1 FAN  Canada
Originally Posted by Sergelisses View Post
Hello Evybody,
I have received a DAC kit today and there is a problem the green LED audio is flashing .
The Spdif input is connected to the Digital output of a CD drive ....
I hope and i suppose that the Digital output signal is not correct !!!!
Have you met such a problem ?
Thanks for your advices
Serge
If it's a standard redbook CD transport(not DVD)it should be outputting the correct PCM data.Maybe try a different cable and or transport.
Old 18th September 2011, 03:09 PM   #682
The problem :
The " No Audio" is flashing , comes from the CD drive .
It seems that sometimes the CD drive is not correctly " initialised " when it is switched on...
Serge
Old 18th September 2011, 08:01 PM   #683
The problem :
Serge
Thats why I suggested trying another transport,or did you and confirm it was the problem?
Old 19th September 2011, 08:55 AM   #684
Sergelisses,
i had the same trouble with the assembled version + scratching in music when led-flashing!!! even the mains transformer was his own! he tried to swing this way as well! after some boxing-mails finally he sent a new one winch works even well with dvd/ blueray.
good luck!
Old 19th September 2011, 10:23 AM   #685
Originally Posted by Nosian View Post
Sergelisses,
good luck!
Thank you for your advices .
I am going to check with two others CD Drive .
Serge
Old 19th September 2011, 05:49 PM   #686
I tried with two others CD drive ans it's the same problem!!!
Very often when i power on the DAC and the CD Drive the No Audio led is flashing ....
Bad news .
Serge
Old 19th September 2011, 05:56 PM   #687
MrSlim is offline MrSlim  Canada
Did you buy a prebuilt board? If so, push the vendor for a replacement..
Old 19th September 2011, 06:00 PM   #688
Yes it's an assembled and tested DAC !!!
I just sent an email to the vendor and i wait his answer .
Serge
Old 19th September 2011, 11:38 PM   #689
Peterma is offline Peterma  Australia
Hi and thanks for the BOM, just a quick question I am trying to get the Evox-refa 100nf 50v smr caps you suggested but cant get any so is there any other cap you would recommend instead?
Old 20th September 2011, 05:51 AM   #690
erin is offline erin  Australia
You could try the Panasonic PPS capacitors......
Panasonic ECHS 0.1uF 100V PPS Film Capacitor - Lot of 5 | eBay
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 03:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 03:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 06:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 02:37 PM
Copyright 1999-2017 diyAudio
