Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 14th August 2011, 02:55 PM   #501
johnm is offline johnm  United Kingdom
johnm's Avatar
P.S. If one is not installing the op-amp output (I'll be using UTC A-20 output transformers) can any of the onboard PSU components be omitted? It looks like C39 and the 7912 reg. next to it can go?
Old 14th August 2011, 03:00 PM   #502
johnm's Avatar
Originally Posted by johnm View Post
I wouldn't think so as it's a 24/96 DAC - unless it's able to downsample?
I need to amend this comment. I believe the receiver (CS8416) can accept 24/192 files. However the AK4393 is 24/96 only. The AK4396 can accept 24/192 though, so I **assume** these DAC kits with AK4396 can playback 24/192 material. Depends how the board/circuit has been configured however... Anybody care to comment? Can this DAC kit (with AK4396) playback accurately files of any bitrate up to 192KHz, or are they all upsampled?
Old 14th August 2011, 03:31 PM   #503
F1 FAN is offline F1 FAN  Canada
Sorry I should have clarified that I 'm building the 4396 version which as you mention is 192k capable.Since there is no sample rate convertor IC there will be no upsampling.
I'm also thinking that by using a small resistor(3-10 ohms)for the the jumper between the analog and digital filter caps(when using a single transformer)might improve isolation between the analog and digital supplies as well as adding some additional filtration?
Old 14th August 2011, 03:33 PM   #504
johnm's Avatar
It depends what's happening between the receiver and the DAC chip though. Does the CS8416 upsample all inputs to 192KHz before sending it to the AK4396 or not?
Old 14th August 2011, 03:42 PM   #505
No it (CS8416)does not change the sample rate.
Old 14th August 2011, 04:11 PM   #506
johnm's Avatar
Right. So unlike the Gigaworks 24/192 DAC (CS4816 + CS4398) this one doesn't need any DIP switching to change from - for example - 16/44.1 to 24/192 files then. Sounds ideal!
Old 14th August 2011, 05:58 PM   #507
No, it leaves the sample rate as it is and the AK4396 version can play anything up to 192kHz.
And as I've mentioned before, I've got an AK4396 version and it plays 192kHz audio flawlessly. (However not totally perfectly, as my chip is defective, but it COULD play them flawlessly. However, that's an other story.)
Old 14th August 2011, 07:07 PM   #508
johnm's Avatar
Thanks for the confirmation Jeffzen - AK4396 kit ordered from Zoe-tsang!
Sorry to hear about your faulty chip - hope that gets sorted out asap! I know these particular chips are very finicky about soldering/heat.
If anyone wants an AK4393 PCB + kit (chips already soldered in place) please let me know (£10 plus £2.50 postage). Bought it before I realised that it could only get upto 24/96.
- John
Old 15th August 2011, 02:39 PM   #509
What about using the inner core from a coax cabel, whith the white isolation on, to connection betwen the dac pcb and rca plug ?
Old 15th August 2011, 07:35 PM   #510
I think it could be okay, but I would absolutely leave the shielding on as well. In my opinion, shielding is one of the most important things when working with a lower level signal.
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
Copyright ©1999-2013 diyAudio
