DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 49 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 11th August 2011, 01:39 PM   #481
Yes, that's the same kit I bought: all SMD parts soldered in.
Old 12th August 2011, 06:40 PM   #482
Am I the only one who misses some bass? and dynamic. Maybe something is wrong with my DAC ??
Old 12th August 2011, 07:16 PM   #483
I use 2 transformers 30va each. At the 2way block i have : 12,81v AC, and the 3 way block : 14,11v Ac. The power total is 0,1A, before the transformers. The 3 regulators is not getting warm at all ? only about 42* Celsius??
Old 12th August 2011, 08:24 PM   #484
Reality first!
ClaveFremen's Avatar
Nothing, you should only apply the suggeste mods...
Start with regulators and LPF capacitors...
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition Group Buy 10th Run.
Old 12th August 2011, 09:24 PM   #485
Okay :-)
on my to do list is : change the 3 nichicon in the psu to Nichicon FW 2200uF 63 v (ordered) change the 2 caps after to Silmic II 220uF 50v(ordered). Change the "c3" digital cap, to Sanyo SEPC 470uF 16v (ordered) change the 3 regulators to Mc****CTG (right ???? ) Other things to change, who has a good improvement ??
Old 12th August 2011, 11:09 PM   #486
pre65 is offline pre65  United Kingdom
I have a completely standard DAC at the moment, but having now read the whole thread will probably get another kit and start modding that.
I see mention of hot regulators. My 15-0-15 transformer was actually putting out 17-0-17 and I did have hot regulators.
Putting a 50R (ish) resistor in each lead (not centre tap) brought the voltage down to 15 and no more hot regs.
Old 12th August 2011, 11:45 PM   #487
Reality first!
Yes, On Semiconductors MC7xxxCTG.
LPF capacitors...
FKP2 or FKS2 or even better the old NOS FKC2, you can find them on eBay.
Insert some carbon films too
Dario
Old 13th August 2011, 12:12 AM   #488
LPF capacitors...
Btw. Any recommendations for the wires between the dac and the RCA chassis plugs ? I use ordinary copper wire (1mm2) But think i can do this better.
Old 13th August 2011, 02:06 PM   #489
nuryev is offline nuryev  Australia
Hi evangelion
do you have any of the boards or kits available for this diy dac?
NYV
Old 13th August 2011, 02:59 PM   #490
awpagan is offline awpagan  Australia
Old cat5 network cable.
Indecision makes the world gone round.
Maybe
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 03:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 03:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 06:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 02:37 PM
Copyright 1999-2017 diyAudio
