DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 260 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 29th September 2013, 08:42 PM   #2591
jdamico is offline jdamico  Venezuela
jdamico's Avatar
Default Other pics
In this second post will share some other pics. Maybe later will be able to give more details (after burn in).
Thanks to all the diyers that shared they experiences, were very useful.
Old 2nd October 2013, 06:28 PM   #2592
ferynov is offline ferynov  Indonesia
ferynov's Avatar
Send a message via Yahoo to ferynov
@jdamico : nice build
my dac in little case...
-Best Regards-
diy blog
Old 3rd October 2013, 02:27 AM   #2593
tofurky is offline tofurky  United States
Default i2s ideas and questions
hey,
i'm considering modding this to use direct i2s input instead of spdif. i have a couple ideas (and a bunch of questions) as to how this could best be accomplished.
  1. remove the 4x 51ohm resistors that send i2s from the cs8416 to the ak4396 (is it OK if there are no resistors between i2s source and sink? some of the usb i2s interfaces i'm looking at don't have them, and i don't see an elegant way to add them into the chain otherwise)
  2. in the now empty holes closest to the ak4396, place a 4 pin 2.54 SIP male header
  3. where the "bodies" of the 51ohm resistors previously were, carefully expose ground plane and solder an additional surface mount 4 pin 2.54 SIP male header. (any caveats or pointers to how to do this? fine sandpaper until i see copper? i would like to leave the board in tact if i want to go back to spdif input later).
  4. use a cat6 UTP ethernet cable for the interconnect. there are 4 twisted pairs, so each pair would have a signal+ground. i would terminate each end of the cable with a (soldered on) crimp connector to mate with the two 4 pin SIP headers on the mini2496 board. (would the standard SIP pins be ok? i've read u.fl is best, but its unfortunately not realistic to do given the constraints of this pcb)
  5. optionally, come up with a way to power off the cs8416 circuit since its unused and would just add noise/emi to the dac (would depowering this completely affect the proper function of the PDN pin on the ak4396, or any other of the connections on the 74HC04?) the three ways i see to do this are:
    • desolder/lift the VD and VA pins (difficult)
    • remove L1 to remove VD power, and lift the input or output pin of the "analog" 3.3v LM1117 to remove VA power (easier)
    • cut traces (bad)
for the usb i2s adapter, there are a few options that use asychronous operation.
  1. diyink cm6631a - isolation
  2. diyink xmos - no isolation
  3. amanero - no isolation
  4. waveio - isolation
i'm leaning towards the cm6631a due to its price and built in isolation. adding an adum4160 into the chain on another dac improved snr considerably. without isolation, it seems like i'm wiring up the dac directly into a usb bus - not ideal.
finally, are there any changes into the operation of the dac that come about with using direct i2s in? which of the leds still work? is there a finicky startup sequence required to get a signal lock, etc.?
thanks,
-matt
edit: removing C28 would provide an alternate ground point for the i2s connection that doesn't require exposing the ground plane
Last edited by tofurky; 3rd October 2013 at 02:56 AM. Reason: another idea for i2s ground connection
Old 28th October 2013, 09:35 PM   #2594
I've just found a pcb with the ICs soldered on. I have a load of bits and the parts from the upgrade BOM.
I've read through posts,but still have the following question, is there anywhere which lists the placement of parts (including the upgrade parts) as a silkscreen type layout?
Many thanks.
Old 29th October 2013, 10:02 PM   #2595
there you go, paths and numbering...https://drive.google.com/?authuser=0...UzNzhjODI5MWRm
Old 30th October 2013, 12:03 AM   #2596
Thanks for the link, I don't have a google account though, is there anyway to login as a guest?
Old 30th October 2013, 10:19 PM   #2597
https://docs.google.com/file/d/0B-qK...?usp=drive_web
i don't think you need to be signed for theseClick the image to open in full size.
Old 30th October 2013, 10:43 PM   #2598
I have finished experimenting with this DAC kit and moved on to another project.
Therefore I have a fully populated & working board and a bare board with only dac chip soldered for sale.
Picture of the populated board can be seen in here:
Please send me a pm if anyone is interested in them.
Old 1st November 2013, 07:26 AM   #2599
Thanks Reg66
Old 8th November 2013, 03:45 AM   #2600
Can anybody tell me how the AK4393 compares to the CS4398?
Reason i ask is i was playing with the USB version of this board with the CS4398 and discovered the USB interface creates distortion so its really only usable with the SPDIF interface. Therefore i have to wonder if this is the better board that i should put my parts/effort into?
Mark
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 03:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 03:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 06:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 02:37 PM
Copyright 1999-2017 diyAudio
