DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 258 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 14th August 2013, 03:44 AM   #2571
Building this AK4396 from a bare board(except surface mount chip); it's ok for resistors,small capacitor (FKP/FKS) but I am a bit in trouble with electro capacitor:exception C23/24/25 and C38/C39 (they are so big ). Someone can show me on the board where is C14/17/31 C27 C32/33/35 C29/34
Thanks for your help
Praudio
Old 16th August 2013, 04:24 PM   #2572
jdamico is offline jdamico  Venezuela
jdamico's Avatar
Hi to everybody.
Is a great thread with great contributors. Very nice reading.
I just bougth the kit unassembled (just waiting to put hands on) and some other parts according ClaveFremen BOM (thanks again to Clave), but trying to save some money, also I'm using some old stuff I have in my spare parts box:
I have a 120 W old psu transformer from a small cheap integrated and dead Sansui amp (55+55W). from the seventies. Transf. is working and in perfect conditions, the secondary is 27-0-27 V but have primary windings in 120, 220 or 240. in my Country outlet ACV is 120, and planning to use mains 120V connected in the 240V primary winding tap, I tested and measured the secondary to be 13.7V and I think this big transformer will go well for the analog supply and will work far away from hysteresys with linear and clean power enough.
Also have some Rubycon 6800 uF 63V caps 85 celsius (japan made) for power supply smoothing and some polypropylene Evox PMR 400V 2.7uF to bypass them.
For the digital supply have found and old wall transformer (without rectifier bridge) from a US robotics external 55Kbps phone modem (do you remember that oldies??), it's 16 watts 120/9 Vac and think is enough power for the digital 3.3V of the two chips that use it. Tested and is in perfect conditions.
I have also some galvanized brass plates 0.25mm thick an will make a enclosure with also some surrounding kind of wood.
Don't want to upset anybody with this, but if somebody can explain me why not to put an optional (on-off, not fixed) upsampling daugther board like CS8421 (like the link at bottom) to have this option enabled. Fikus from lampizator says it's sound is "heaven" in a behringer ultramatch pro. I believe that maybe putting a 6PDT switch like this (link at the bottom) I found on ebay in the path of the R12-R15 resistors (it's not so complicated) we can have a very short wire switch for the digital signals involved (also there are 8PDT switches if want to switch master clock). I only want to hear oppinions and experiences with the electronic upsampling implementation (not the software). Some years ago I bougth a Gigawork (lars) upsampling DAC and modified it. Sound is not bad at all. Thanks in advance for sharing the experiences and apologize for my bad english.
Josť D'Amico
Stereo Parts Pioneer Switch Push Button Speaker 6PDT | eBay
CS8421 Upsampling Board Suitable for AD1955 DAC Decoder | eBay
Old 17th August 2013, 03:09 AM   #2573
hey,
so about to start diy audio, which is going to be awesome<
and am starting with this kit<
just wanted to make sure i was getting the right one, might use that awesome new BOM some time in the future,
so it this the way to go KIT ??
and i was thinking i would get a tube buffer for it, really want to try the tube sound,
any thoughts on using this tube Buffer
the other question, will the R type transformer work with 230V electricity ( im a Aussy) ?
Old 18th August 2013, 11:44 AM   #2574
sorry for double post, but, all i need to power this a 15*2 R-type transformer ?
Old 18th August 2013, 01:02 PM   #2575
Reality first!
ClaveFremen's Avatar
Look in the first pages of the thread. I've posted a pic of the PCB with parts numbering.
That 9Vx2, 15Vx2 transformer is the correct one.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition Group Buy 10th Run.
Old 18th August 2013, 01:16 PM   #2576
cheers mate, just ordered, cant wait till mid semester for build time.
am sure i will have heaps more questions
Old 19th August 2013, 12:31 AM   #2577
jdamico's Avatar
Will receive the kit in two weeks.
Edited the schematic of this Thread to explain my intentions, maybe is better than write. If someone tried to put switches before on this or a similar board, or already knows if it works (or if this mods can have some trouble), please advice me.
Old 29th August 2013, 10:43 AM   #2578
hey, sorry for silly question, ( this thread prob needs a edited first post with some FAQ's i n it )
but how do i take spdif into it,
am i going to have to do some funky wiring straight of my motherboard, or do i have to get something else ?
Old 29th August 2013, 11:15 AM   #2579
okay i think i worked out my own question above(sorry for double post) ,
i have noticed some people with external bridge rectifiers and capacitors, are we supplying rough dc current to it instead of AC for better performance?
Old 29th August 2013, 02:35 PM   #2580
erin is offline erin  Australia
Do you understand how a power supply works?
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 03:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 03:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 06:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 02:37 PM
Copyright ©1999-2017 diyAudio
