DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 244 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 22nd February 2013, 11:13 PM   #2431
tofurky is offline tofurky  United States
Originally Posted by reg66 View Post
sorry to trouble you clave, i'm trying to this without asking you too many questions and also not pester my dad too much...
but, to the right of C28 is a capacitor that is unmarked according to your paths and numbering diagram. what goes there?
pretty sure its the 1uf 50v
-matt
Old 22nd February 2013, 11:20 PM   #2432
yep, it says 1u at that point, so that would make sense. but does this mean just use the stock one, or should i have ordered it? i can't see it on the BOM
i know i seem to have answered my own question because it's not on the BOM, but i just want to make sure...
oh, and thanks for the prompt reply!!
Old 23rd February 2013, 10:58 AM   #2433
Reality first!
ClaveFremen's Avatar
Use the stock one, that cap decouples the chip driving the leds... not in signal path.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition Group Buy 10th Run.
Old 23rd February 2013, 11:49 AM   #2434
thanks very much indeed
Old 23rd February 2013, 02:00 PM   #2435
i'm quite nervous about soldering the brown dog together (this is my first soldering project!). i have some very thin solder and a fine tipped iron. do you think the direct approach is ok, or is there some more reliable technique. i've seen clave mention tacky flux, but it expensive for a tube. being my first project, i'm quite cumbersome when it comes to soldering. any advice is much appreciated
Old 23rd February 2013, 02:11 PM   #2436
atupi is offline atupi  Romania
There is nothing to be afraid of, just make sure you clean with alcohol the small browndog pcb. Solder just one terminal of opamp and check if the other pins are alligned and solder one by one. Make sure you have enough light and if you feel the need use a magnifying lens. If, by mistake, some pins are bridged use solder wick to take out the unneeded solder.
Good luck !
Rega RP-1/Simplistic RIAA by Salas/ DCB1 clone/ MyRef Fremen Edition/FC-100/ XTZ 99.26 MkII speakers
Old 2nd March 2013, 01:28 AM   #2437
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Damn, I damaged my ak4396 dac.
Old 3rd March 2013, 04:16 PM   #2438
mepper is offline mepper  United Kingdom
Default Blowing fuses
Hi all, finished assembling mine this morning using Dario's BOM - thanks so much for putting it together Dario!
Only problem so far is it's blowing the IEC socket's fuse at power-on about 50% of the time, and I'm already up to a 250mA (fast blow) which is quite a bit higher than the 100mA or so I've found mentioned in a few posts in this thread. What's everyone else using?
I have a 230V RN-20 R-core transformer btw - pretty standard there.
Thanks!
Old 3rd March 2013, 04:47 PM   #2439
bcmbob is offline bcmbob  United States
I have also had several fuses blow and it seems it is related to on/off surge. I'm up to 3 amp slo-blo on the U.S 120 volt format.
How do you like the sound? (assuming it has stayed on long enough)
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 3rd March 2013, 05:25 PM   #2440
Bob, I am using 1 amp slow blow fuses. The problem is the transformer initially pulls a high current to form the magnetic field and charge the capacitors. Then it settles down to a lower current draw.
P.s. my transformer is 120VA with 4 sets of 15v-0-15v 30w secondary's, so 250ma fuse should work in slow blow form...
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 03:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 03:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 06:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 02:37 PM
Copyright 1999-2017 diyAudio
