| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#2401 |
Deffo better than CS8416 been doing A/B comparison all afternoon.
If you give up easily Dont start!! |
#2402 |
CM6631 USB DAC Coaxial fiber 192KHz/32bit(I2S) 192K(24BIT)SPDIF WLX-66 | eBay
Just ordered this CM6631 it goes all the way to 196Khz
#2403 | ||
I have thoroughly investigated and experiemented with the sound of different diodes, and found that stealth are a waste of time because they all sound different depending on brand and type. And should only be used in high powered situations such as power amplifiers - and only if you can't find a suitable schottky. Schottky mostly all sound the same, irrespective of brand or type. Schottky used as a bridge rectifier provides a lower level of "grain" to the audio, and greater overall clarity. I recommend 11DQ06 or 11DQ10 because they are cheap and sound great.
http://www.everyonedeservesadayoff.com/ Last edited by erin; 3rd February 2013 at 12:59 AM. |
#2404 |
Hi Erin,
my kit came with ferrite beads (Along) and yes I checked out the stealth diodes and saw they were for power amps. Going to try some of those PETP caps in bypass mode on the PSU caps on one board and maybe some polystyrenes in place of Wimas - need to see if Dario's Wimas change my mind on Wima caps in general. Diode bridges are easy to make and as always air is the best dialectric, rather than tightly shrouded in plastic - same goes for signal wiring. It is'nt only the design of the naked Vishays that makes the difference, it's the dialectric.
Black Stuart |
#2405 |
Hi hotiron,
I tested the exact same two boards months ago. Bypassing the CS8416 is the way to go if your source is a computer, but I2S connection can be tricky. Your tenor board already has 33R damping resistors on I2S lines, I think you don't need to keep the resistors on the dac side of the I2S lines. Or did you keep them on purpose after checking over/undershoot with a scope ? Mine was really improved when I replaced the USB 5V rail by a linear psu and isolated the USB lines with an Adum isolator (search forum for "Teralink X2 clock mod" for inspiration). |
#2406 |
Hi Bismuth thanks for that I never actually noticed the 33R resistor pack on the TE board, Once I get it built into the case I will give it a dedicated power supply and shorten the I2S leads I need to disconnect the power rail to the CS decoder also. But so far this setup is walking all over the CS8416. Just ordered this board also, can't wait for the postman to come now, probably be a couple of weeks. Doesn't appear to be any nasties on the I2S lines.
http://www.ebay.co.uk/itm/3308176603...84.m1497.l2649
#2407 |
Black Stuart, the Wima FKP caps are very good. They are film and foil, not metalised! Film and foil are the best capacitors. But polystyrene are also film and foil. But I have found that the little silver axial polystyrene caps are not wound very evenly, and this is why FKP will sound better, but of course you must try it for yourself.
http://www.everyonedeservesadayoff.com/ |
#2408 | |
A much better solution is to build your own USB power cable and inject power separately. Doing it this way avoids ground loops and gives a direct connection of the data lines from PC to USB converter. I know this as fact because I have tried the ADum4160 chip, and also used the power injected USB cable.
http://www.everyonedeservesadayoff.com/ Last edited by erin; 3rd February 2013 at 11:53 AM. |
#2409 |
Strangely enough Erin I have just hacked up a USB cable to do that very thing.
#2410 |
| AK4393 burn... | CIMONE | Digital Line Level | 5 | 24th June 2011 02:12 PM |
| AK4393 to CS4223? | CIMONE | Digital Line Level | 0 | 13th December 2009 02:30 PM |
| AK4393 Serial Configuration Problem | Aoxomox | Digital Line Level | 0 | 20th March 2009 05:25 PM |
| AK4393, CS8413 and CS8414 Data Sheets | Blue_Max | Digital Source | 0 | 23rd December 2004 01:37 PM |
