DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 236 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th January 2013, 11:16 AM   #2351
erin is offline erin  Australia
Well, I don't know if you have heard the sound of a genuine OPA627 before?
I bought some of the dual to mono OPA627 from Audjade in May 2011.
To my ears, they don't sound anything like an OPA627! I don't believe them to be the genuine article. On the off chance they genuine, I believe them to be static, or thermally damaged to the point where they sound nothing like they should.
My recommendation would be to stay away from op-amps from that seller.
Of course your experience might be different, my gripe is not with you, but the seller Audjade.
Old 7th January 2013, 07:06 PM   #2352
Hi Erin,
AudeJade states cleary that these modules use s/hand op-amps so your comments about thermal damage are probably right. For the price it's worth a punt especially as this DAC uses a voltage out chip and using the op-amp is my second choice. The caps I bought from him measure fine - he certainly packs his stuff very well.
I saw something interesting about Schottys but they are type that is no good for the DAC as they are 600V and TO-220. So I shall make Schotty bridges from the axial type.
Black Stuart
Old 7th January 2013, 09:03 PM   #2353
Djinn is offline Djinn  Norway
On the board near the 1N4148 diode, next to C28 (Nichicon LF 10uF 16V) there is originaly an 1uF 50V capacitor, but I can not find anything in the BOM of an supstitute?
On the populated picture on the google drive, there is a cap there but I can not find anything about it?
With regards
Martin
Old 7th January 2013, 10:27 PM   #2354
With regards
Martin
Search and you will find, so I did and found the answer in post 1679 Click the image to open in full size.
Old 8th January 2013, 10:41 AM   #2355
I've bought caps from him before and they were fine.
Just personally can't recommend the op amps. There is a saying, if its too good to be true - it probably is. I think these op amps are an example of this.
Old 8th January 2013, 11:23 PM   #2356
spicer is offline spicer  Canada
I bought the dac with some pieces on it.
PCB SMD IC New Hi End DAC 24 Bit 192K Hz AK4393 SC | eBay
I want to build it like yours.
what are the stats (value) of pieces that you didn't change on your dac?
Ex. L1 NPO
Thank
Spicer
Old 9th January 2013, 01:57 PM   #2357
Erin,
did you give AudeJade/Ma Lee a chance to put things right re. the op-amps. If I find that the op-amp module is crap I will get in touch with him, quote - If you are not satisfied, please don't give negative as I will try my best to resolve problems - just contact me.
Well did you?
Black Stuart
Old 11th January 2013, 03:13 AM   #2358
Default 10nF FKP2 opamp decoupling alternative size and type?
I see Darios BOM recommends the FKP2 10nF, and I am also using this one and I think it sounds really really nice.
But if I would like to try say an alternative like a polysterene or say any other type of cap "in the spirit of a true DIY'er" that I just could not get in this value, would a 6.8nF capacitor be much of a problem/loss here?
PS! Thank you very much for your previos reply Dario.
With kind regards
Martin
Old 11th January 2013, 04:40 PM   #2359
Would someone be able to tell me what the maximum current for the bipolar 15V supply and unipolar 9V supply?
Also is there layout diagram for the pcb showing R1,R2 etc?
Old 11th January 2013, 08:15 PM   #2360
Reality first!
ClaveFremen's Avatar
I wouldn't go lower than 10nF. Polystirene are a good choice.
You're welcome Martin.
Dario
ClaveFremen "Bailando Salsa en el Sietch"
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
Copyright 1999-2017 diyAudio
