DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 235 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 24th December 2012, 12:40 PM   #2341
Hi, A question. I had actually used 170R instead of the recommended 150R as I did not have them available. They were normal 5% tolerance carbon comp resistors. Should I bother changing? My reasoning was that being part of LPF that might change the frequency cut off a bit but not too much.
Old 1st January 2013, 10:39 AM   #2342
A quick question.
I have ordered a 4393 kit, which I am going to upgrade.
However I see that the 4396 is a better beast.
The question I have is this, is it possible to replace the 4393 with a 4396 chip.
I assume the LPF resistors would need to be changed.
Is there anything else which would need to be changed to accommodate a 4396 chip?
Also is ebay the best source for a 4396 chip?
Many thanks.
Old 1st January 2013, 11:42 AM   #2343
erin is offline erin  Australia
Yes. Direct replacement.
As you said, install the AK4396 datasheet LPF values.
Yes
Old 1st January 2013, 12:09 PM   #2344
Brilliant,
Thanks for the response.
Old 1st January 2013, 04:09 PM   #2345
@Holmes81 - Its not easy to desolder/solder such chips. There are quite a few videos on youtube which you can check by searching for SMD soldering.
Old 4th January 2013, 11:57 PM   #2346
Djinn is offline Djinn  Norway
Default 160 Ohm Riken alternative
The Riken 160 Ohm seems impossible to source but has anyone tried the Shinkoh 150 Ohm tantalum resistors on the input to the opamp?
In my 4396 kit all the resistors on the output is 1K Ohm and not 2.4K Ohm, but according to Darios Upgrade BOM I am putting in 2.4K Ohm PRP 1/4 Watt, that I found availiable at Hificollective.
PS? I am going to use the OPA827 on the Blackdog adapter as opamp
With kind regards and hello to you all
Martin
Old 5th January 2013, 12:33 AM   #2347
Reality first!
ClaveFremen's Avatar
Hi Martin,
Use a plain carbon film then , IMHO the Shinkoh is too much colored.
It's normal all kits are shipped with LPF parts for AK4393
Perfect.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition Group Buy 10th Run.
Old 5th January 2013, 07:54 AM   #2348
Hi, Are these values so critical? I found only 170 Ohms in my goody bag and they seemed to work out ok. Will a few ohms make a big difference on the LPF?
Old 5th January 2013, 08:28 AM   #2349
atupi is offline atupi  Romania
170 ohm will do the job very well.
Old 7th January 2013, 11:40 AM   #2350
I thought I should give a heads up to AudJade (Ma Lee) - I bought some Silmic11s and a dual-to-mono OPA627(s/hand op-amps) module from him.
They arrived today, superbly packed, the op-amp module in anti-static packaging and acccompanied by something I have never seen before - two rubber fingers (imagine miniature condoms) to handle them with - what a brilliant idea. I actually use very thin white cotton gloves, cheap as chips when bought in Spain, where I used to live.
Also included was an invoice in correct English (how many non Chinese can write in Mandarin or any other Chinese dialect?
The soldering of the op-amp module is excellant - and yes the pricing is as well - what more can you want. I buy very little in Europe because the attitude is - 'how much can I screw you for'. I also buy in the USA because Americans demand 'bang for the buck' but many sellers there screw you on postage - they don't get my business.
Caveat Emptor - but not in this case - chapeaux AudeJade.
Black Stuart
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 03:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 03:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 06:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 02:37 PM
Copyright 1999-2017 diyAudio
