DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 231 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 4th December 2012, 07:29 PM   #2301
Originally Posted by DarpMalone View Post
I'm not very technical and I'm just learning things along the way here, but have you considered just changing the resistors on the 317/337 board to get +/- 12v out? and omitting the 7812/7912 altogether?
Thats also a good idea. I was just thinking of doing something diff. and I had these 2 PSU boards with me lying around..
Old 5th December 2012, 10:50 PM   #2302
Peterma is offline Peterma  Australia
Thanks erin for your help with local parts distributer, just a question reguarding using a higher value cap, is it ok to use 3300uf for caps C23, C24 and C25 would this increase output voltage and cause damage to board?
Old 8th December 2012, 05:35 PM   #2303
my board finally arrived today. on close inspection i can't see any shorts on the legs of AK4396, although i'm sure i read somewhere that a couple of the legs should be intentionally shorted. all of my connections look clean per leg. Is this right?
also, i remember seeing some wimas on the under side of the board. was this dario's final board or someone elses (if you're around to answer dario)
Old 8th December 2012, 06:40 PM   #2304
bcmbob is offline bcmbob  United States
Check HERE
Yes, Those wimas are part of the upgrade. I couldn't find them either
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 8th December 2012, 07:35 PM   #2305
Reality first!
ClaveFremen's Avatar
Don't worry. The pads are already shorted on copper layer, some boards have also pins shorted but it's a question of cleaning...IMHO.
I'm still here...
It was a pic of one of my builds.
Mounting some caps underboard allow more space on the upper side but it's not required if you manage to fit all on one side.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition Group Buy 10th Run.
Old 8th December 2012, 08:22 PM   #2306
great, cheers guys
Old 8th December 2012, 11:32 PM   #2307
Max1410 is offline Max1410  Germany
@Dario,
I have built the DAC like in your BOM, but Mouser has not the Nichicon LF 100uF/16V (C28, C30) on stock. I get this in February 2013!
On stock I have Nichicon BP and FW ( 100uF). The other way is to buy via E-Bay Sanyo OSCON 68uF/20V or 180 uF/20Vbut here are again shiping cost.
What shout I do? For the mean time buit one of the stock (Which BP or FW?) or buy of the Oscons? It is only the C30, because i go with the I2S Interface of one DSP direct to the AK4396 (behind the CS...).
Next to the C28 is a second electrolytic capacity (1uF) without Number. What shoul I put on this place i have Nichicon 10 uF it is o.k.?
Old 9th December 2012, 12:47 PM   #2308
erin is offline erin  Australia
Using a higher value will not cause any harm regarding voltage because there are regulators after the filter capacitors. If you check my fifth post. I use 22,000uf in this location.
What larger capacitance will do is reduce the ripple. As long as the part fits, I would highly recommend going for larger capacitance in this location.
Old 9th December 2012, 01:40 PM   #2309
zdr is offline zdr  Belgium
zdr's Avatar
Anyone compared this to DacMagic or similarly priced stock DACs? I see it has been asked before, but did not see the answer.
Old 9th December 2012, 10:26 PM   #2310
Reality first!
They're a more tight fit but you can order the 270uF ones (647-PLF1C271MDO1)
Or you can try Nichicon FP-CAPs (647-RS61C101MDS1JT), an italian forumer recommended them as the best digital caps ever but never managed to try them...
Otherwise order from ebay Sanyo SEPC
Whatever 1uF elco.
That cap has no influence on sound.
Dario
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 03:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 03:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 06:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 02:37 PM
Copyright 1999-2017 diyAudio
