DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 215 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 2nd October 2012, 03:32 PM   #2141
diyAudio Moderator Emeritus
jean-paul's Avatar
Yes. The output voltage always is higher when the load is light.
It's only audio. Member of the non modular PCB design committee
Old 2nd October 2012, 03:59 PM   #2142
rpfunk is offline rpfunk  United States
Jean-Paul - thanks for the quick response. I'll feel better about leaving it on for an extended period of time now. I will put a heatsink on the LM7812 though. Its really does get hot.
Old 2nd October 2012, 04:02 PM   #2143
jean-paul's Avatar
Measure the voltage over the filter caps and compare with their rating. I forgot exact values but you understand that, for instance, 20 V DC on a 16 V cap won't be beneficial for longevity.
You are right about the heatsink.
Old 2nd October 2012, 04:53 PM   #2144
I'll do that. Originally I was going to buy the board and components separately, but changed my mind and got the kit instead for an easy project. I think now that maybe I should have stuck with my original idea.
Old 2nd October 2012, 06:29 PM   #2145
bcmbob is offline bcmbob  United States
My two cents
It's been my experience the starting with a complete kit offers some reassurance to builders with entry level or moderate experience like myself. Unless one has some advanced knowledge, there can be a lot of "Hunt and Peck" in parts selection. IMHO, most of the upgrades are not that expensive and each builder should decide if the safety factor is worth the extra dollars.
At the rate I going I won't be able to hang out my "Guru" shingle till around 2047. Till then I'll probably lean toward starting with kits
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 2nd October 2012, 09:26 PM   #2146
The thing that swayed me on the complete kit was the fact that I have 2 other DIY audio projects that I have not completed (and I started them months ago). One a tube amp 90% done and the other a AMB input/output selector - attenuator - Display processor at about 80% done. The AMD project requires several very small connctors to be built which I have yet to complete since I don't have the correct crimping tool. The tube amp just makes me nervous. With this kit I received it in the mail and had it working the next day. I remember spending quite a bit of time on mouser doing the "Hunt and Peck" portion my other 2 projects.
Old 4th October 2012, 07:05 PM   #2147
May be a stupid question but I have just received my 4398 board and:
The schematic show the 'analogue' section fed from a 15-0-15 supply with the CT grounded.
But no earth is shown on the 9-12V 'digital' ac supply. Should one of these also be grounded and if so, which of the two terminals? Or is is it just left to float, or does it pick up its reference voltage from the earth on the 'analogue' supply?
Old 5th October 2012, 07:18 PM   #2148
Hi, I now use my pc with a USB SPDIF converter to supply my AK4396 dac.
I have just had a tinker and plugged the dac directly to my power amp.
I like the sound much better this way so would it be possible to put a volume pot in between the dac and power amp.
If this is no problem, what value would be best 50k, 100k.
My amp is the Linn LK280 which I believe has a strange input impedance. 3k ohms I believe
Old 5th October 2012, 08:44 PM   #2149
This is much more than is necessary, but may be helpful. Shielded Pot
Also - here is a simple diagram. SMD Pot - from eBay.
Bob M.
Old 6th October 2012, 10:59 AM   #2150
Attachment 304906
Hi Bob, would you rcommend this pot and it's value 10k over say a blue alps pot
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 03:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 03:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 06:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 02:37 PM
Copyright 1999-2017 diyAudio
