Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 30th May 2012, 07:07 PM   #1821
Default is this something?
hi everyone, some time ago i was looking for a simple low-volt low-impedance low-noise psu to this dac and i found this on some blog that dose not works anymore. i wonder if it is real? works? or ... any idea?
Old 30th May 2012, 07:58 PM   #1822
atupi is offline atupi  Romania
I've seen this "capacitorless" power supply on DAC designed by a russian guy but i can't remember the name now. Worth a try and would be good if someone more knowleageable (like Andrew) would say something about this design.
You can try the shunt regulator used by Dario in his MyRef_FE.
Old 31st May 2012, 02:48 AM   #1823
erin is offline erin  Australia
It was designed by diyaudio member Nazar_lv diyAudio - Creative High end audio
His website is here http://overture.org.ua/?cat=27
He is one of the best engineers on this forum. Of course it would work.
The explaination of the circuit is on the link above. Happy reading.
Old 31st May 2012, 07:15 AM   #1824
atupi or Dario i searched the forum for MyRef_FE but i came back to this post!!!
do you know any direct link?
Old 31st May 2012, 07:17 AM   #1825
and i found
at TNT: "... where the 431 is used as a shunt-controlling amplifier driving an emitter follower. Output impedance can be much lower than with a solitary TL431. No noise measurements were done (yet), but I expect them not to be substantially different from the above ones...."
any comments? suitable to this dac?
Old 31st May 2012, 07:28 AM   #1826
Strange the LM1117 is a 3.3v for 3.3v output.......
I tried it ( +5v ) a few weeks ago for the AK4396 +5v Ana .
For me the SALAS Shunt reg is better .
It's my opinion
Serge
Old 31st May 2012, 08:04 AM   #1827
Hi Everyone,
I am actually in need of some help.... I just got one of these Gigawork Dacs with a PCM1794+DI9001+PCM2902E
Upsampling 24bit/192 DAC KIT,TOROID TRAN,USB, PCM1794+DIR9001 | eBay
My problem is with the Toroidal Transformer. I am pretty sure I have the wires going to the board right, but the AC IN wires I just want to make sure. They are 4 wires (2red, 2black). I twisted the 2 red wires together and 2 black wires together for 110V. Then basically I put them into a plug / socket that goes into the wall.
The closest I got was two 12V LEDS to come on the board, nothing else. No Sound or Anything... Any help would be greatly appreciated!
Old 31st May 2012, 08:15 AM   #1828
50AE is offline 50AE  Bulgaria
I built the Salas shunt and I highly recommend it!
Old 31st May 2012, 10:44 AM   #1829
hotiron is offline hotiron  Scotland
hotiron's Avatar
Can you post a pic of your transformer Slider?
If you give up easily Dont start!!
Old 31st May 2012, 01:34 PM   #1830
And what do you measure as secondary voltages? Also, what colors on the secondary winding do you have, and how much volts do they give (without load).
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
Copyright ©1999-2013 diyAudio
