Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 29th May 2012, 09:06 AM   #1811
Reality first!
ClaveFremen's Avatar
Originally Posted by apoo View Post
I´ve lost my orientation in this huge topic.. Can somebody tell me where i can find the post with the link with the BOM
Hi apoo,
you can find my upgrade BOM, together with other relevant files, here.
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 29th May 2012, 09:13 AM   #1812
Reality first!
Originally Posted by nphil View Post
I just used the 0.22uF Wima MKS2s instead of the orange Chinese 0.1uF caps, on either side of the op-amp. The logic for using 0.22uF MKS2s was as following...
Those 'Chinese' caps are actually Korean ones made by Pilkor (ex Philips Korea) and they're not so bad.
BTW I recommend good quality electrolythics (47uF) in those positions.
Dario
Old 29th May 2012, 10:37 AM   #1813
50AE is offline 50AE  Bulgaria
News from mee! I've almost finished the external power supply! Here are the extras
-Separate heater transformer
-Much better grounding, center tap for the heaters, beter cable paths, twisting
-Attenuator for the DAC (not done yet)
-New output caps (RIFA PME271M)
There is more to be done on the outside, it's just a matter of money and time
Pic 1
Pic 2
Pic 3
Pic 4
Pic 5
Pic 6
Pic 7
Pic 8
Old 29th May 2012, 03:23 PM   #1814
atupi is offline atupi  Romania
[QUOTE=bcmbob;3013882]Attachment 280903
Attachment 280904
Attachment 280905
No, I'm not that good. Shown after clean and polish.
Attachment 280906
Bob, i see one elcap close to the buffer opamp is damaged, top part is roundish.
Old 29th May 2012, 05:04 PM   #1815
bcmbob is offline bcmbob  United States
atupi - Good Eye. The DAC is working great but I'll replace it (probablly both) on my next to-do list. I used all the parts from a build I messed up on a new PCB so I feel lucky it's working at all. I use double sided carpet tape for sorting parts and will avoid placing them upside down in the future. Could have been the cause.
Only thing I couldn't salvage were the LEDs. Popped in some Radio Shack generics.
BTW, Should get this package today. Bought it to compare the WM8741 to the AK4396
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 29th May 2012, 07:10 PM   #1816
does any one have a good and simple circuit for the 3.3 and 5v rails? if Dario had something on mind?
Old 29th May 2012, 08:03 PM   #1817
fulvio is offline fulvio  Italy
Nosian, I've just finished a power supply with four TL431 shunt regulators (+12V, -12V, +3.3V, +5V); it works.
The +20VA, -20VA, +20VA2, +12VD, -12VD come from a separate PSU, with two separate transformers and big filter capacitors.
Fulvio
Old 29th May 2012, 08:15 PM   #1818
thanx you nice Italian. I loved the Nina Zilli's performance in eurovision on Saturday. cheers.
Old 29th May 2012, 08:34 PM   #1819
merlin2069er's Avatar
Send a message via MSN to merlin2069er
I'm using a couple of super teddy regs for 3.3v + 5v...
TeddyPardo
Old 29th May 2012, 08:51 PM   #1820
thanx Merlin i wish i could robb a bank!
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
