DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 177 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 10th May 2012, 10:32 PM   #1761
bcmbob is offline bcmbob  United States
Thanks, Thought there might be someone running "Blue Light Specials" and was U.S. based. I guess we just have to choose between "get it now" and "get it cheap"
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 11th May 2012, 04:39 AM   #1762
redjr is offline redjr  United States
Bob - I'm sure these same disconnects are available from suppliers in the states. I just haven't looked hard enough. I'm sure Mouser, or Newark have an equivalent, but the soft, silicone/soft plastic sleeve are really nice and make handling them easier. I've got a good stock of them now though. I recently bought some right-angle disconnects to try, but short of using a vise I can't figure out a good way to crimp them. A normal crimper won't work! Oh well.
Old 11th May 2012, 08:18 AM   #1763
Originally Posted by hotiron View Post
DOH!! Posting pics like that on here makes for newbies thinking this practice is OK!!
1. I do not claim that this is state of an art model.
2. I fully agree that leaving 2 bare terminals of mains cap and socket is dangerous, though I've seen it in some factory audio/ video components as well and moreover, it's ok for me in this dac where nobody except me will take off the top cover.
Not sure how you manged to use Darios BOM either cos its a different PCB!!
well at least I'm sure indeed it's a different pcb, different chip (AK4398) + chip for usb has been added, nevertheless it is still 80% the same schematics. Pls see attached pdfs.
I take it the idiot has naffed off to show his work off to some other thread or forum even.
240 AC volts needs to be treated with the utmost of respect, It will kill you before you even don't want to know it.
with all respect to the forum and to you, don't make a panic out of nothing and leave your offensive comments with you!
Old 11th May 2012, 08:35 AM   #1764
Originally Posted by redjr View Post
I did. My local AutoZone wanted about $3.50 for 8 insulated disconnects. Highway robbery in my book.
That is expensive. I can get 100pcs for less than 5 quid here in the UK.
Old 11th May 2012, 12:50 PM   #1765
This probably should be in the techniques thread - but I've pretty much given up on the pre-insulated connectors. The most economical method with U.S. parts has been a combination of the following.
Quick Disconnects here
Heat shrink Tube here
....available in colors or all black.
Larger size long enough to overlap small tube.
I've just had too many crimped wires come apart so I solder everything.
Custom results with the ability to disassemble if needed.
The only other good value packages I've found for pre-insulated pieces are here but their shipping charges up the cost. Radio Shack "Ship to store" saves a few bucks.
Bob M.
Old 11th May 2012, 01:04 PM   #1766
I always solder to the disconnect too, just to make sure there's a solid connection. I've thought of using heat shrink tubing on them, but have never tried. HS tubing adds a degree of security to the connection as well, and looks professional. Gives it a nice 'tight' appearance. Yeah - I'm afraid we've wandered a bit OT.
Old 11th May 2012, 01:26 PM   #1767
palmito is offline palmito  United States
palmito's Avatar
For those that live in the US and have an ACE Hardware store close by, they sell these connectors by the piece (i.e., not in a package but individually).
Old 11th May 2012, 01:33 PM   #1768
Yes, and please note that what they call "High Temp" actually cost a little less.
Bob M.
Old 12th May 2012, 12:41 AM   #1769
VT67 is offline VT67  Belgium
VT67's Avatar
Does anybody here knows what type of Ferrite Bead is used for L1 & L2?
Old 12th May 2012, 04:49 AM   #1770
TheGimp is offline TheGimp  United States
TheGimp's Avatar
In the USA, check out Lowes, Home Depot, etc. They have them in blister-packs at reasonable prices.
Personally,I buy them in 100s as they are much cheaper that way.
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 03:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 03:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 06:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 02:37 PM
Copyright 1999-2017 diyAudio
