DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 170 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 24th April 2012, 09:22 AM   #1691
I have a quick questions for those who bought only the pcb. Bottom left corner shows 10k R, while it's 100k on the scheme I've got from supplier. What value should I use?
Old 24th April 2012, 11:23 AM   #1692
billo44 is offline billo44  United Kingdom
billo44's Avatar
Your PCB hyperlink seems to be a picture of a different board to the pcb discussed here.
I'm no expert but it has different chips in different places.
Also your board has an USB input....
Bill
Old 24th April 2012, 11:30 AM   #1693
VT67 is offline VT67  Belgium
VT67's Avatar
Indeed, we are talking about a different board here.
Picture shows the same setup but for the Mini2496 and there is no resistor at all.
Old 24th April 2012, 11:49 AM   #1694
This picture is for a board, with USB support. Basically it is the same, but still different.
Old 24th April 2012, 12:11 PM   #1695
bcmbob is offline bcmbob  United States
Has anyone determined a preferred spec (part number) for the on-board LEDs ?
Also, C40 and C42 are listed in the upgrade BOM but are not installed in the picture from the Goggle Docs ?????
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 24th April 2012, 12:25 PM   #1696
indeed, the layout is different, the rest is the same, just added usb input (CM102).
Old 24th April 2012, 01:10 PM   #1697
VT67's Avatar
They are at the bottom side of the board.
If you look closely you can see the leads sticking out on top of the board
regards
Old 24th April 2012, 01:26 PM   #1698
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Should a new thread be started for the USB (CM102S) variants of the board?
I've got one on order with the CS8416 + CS4398.
From looking at the schematics it seems to me that there are about five variants of these boards using the CS8416. All use basically the same power supply and output filter with component value variances.
In general, mods to one are applicable to any of the others with the exception of the output DAC having different features (especially the pinout changes for the CS4398 vs AK4393 and AK4396).
I realize the thread was started specifically for the AK4393, but it evolved to encompass the AK4396 as well, so it seems to make sense to include the newer AK4398 boards as well.
What makes sense to me may not agree with the OP, so I am asking before posting more on the AK4398.
Respectfully,
Steven
Old 24th April 2012, 01:34 PM   #1699
Thanks VT67, Now that you point it out I remember seeing that on some other builds.
Bob M.
Old 25th April 2012, 10:01 AM   #1700
thanks a lot!
then probably I would use your reg - LM317+BD139 + U6 for A+3.3 part.
I've got the parts for PS finally and curious now, is it safe to omit U6 at all, I mean if I stay with simple shunt from Dario (LM317+BD139+zener) could I directly feed CS8416 A+3.3 bearing in mind voltage peaks during switching on/off the dac?
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 03:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 03:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 06:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 02:37 PM
Copyright 1999-2017 diyAudio
