DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 157 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 10th April 2012, 07:55 AM   #1561
Reality first!
ClaveFremen's Avatar
Originally Posted by billo44 View Post
Here are bigger pics including the legend on the Transformer.
Originally Posted by TjiptoHendrawan View Post
I think the connection should be blue (15) - black and blue (0) - black (15)
Exactly.
According to the label you shoud use (they should be in pairs)
BLU1 -> 15V
BLK1/BLU2 -> 0V
BLK2 -> 15V
Usually the first color in pair is phase and the second is neutral
Originally Posted by idjoel2000 View Post
looks interesting, dario.. how can we make the +9V version?
The regulator is pretty easy to adapt, you simply change the zener considering that the output voltage is the zener voltage with 0.6V added.
Also you should calculate the maximum required current, increase it by 15mA and use that current to calculate current setting resistor (1.25V/current).
But I don't know if in digital applications it is any better than a OnSemi MC7809.
Originally Posted by dtses View Post
indeed it's much simplier, though have you done any face to face comparison with Salas? Also why do you think it would be an overkill for opamp?
No, Salas shunt is for sure superior.
I think that probably a Salas shunt is overkill since opamps have high PSRR, while in a simple discrete circuit, like the DCB1, PSRR is much lower.
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 10th April 2012, 10:25 AM   #1562
billo44 is offline billo44  United Kingdom
billo44's Avatar
"Exactly.
BLU1 -> 15V
BLK1/BLU2 -> 0V
BLK2 -> 15V
Usually the first color in pair is phase and the second is neutral"
Thanks Dario!
I hooked together the/a blue black pair with 0 continuity as per apoopoo999's kind advice, but I still have no analogue output.
I'm sad now!
Burst another bubble
Do a get an award for 'DIY Dumbo of the week'?
As I see it there are three logical possiblilities ....
1) I haven't fixed the AC supply issue correctly.
2) I damaged some/several components by applying AC power incorrectly.
3) There was more than one problem/error in the first place, and there is another error(s) still to correct.
I think some of my peers on this forum will know if 2) above is likely?
As always I appreciate any advice you can offer peeps.
Bill
Old 10th April 2012, 10:33 AM   #1563
Reality first!
I'm sad now!
Hi Bill,
just to be sure measure (trsanformer only) AC from BLU1 and BLK1/BLU2 (it should measure 15Vac) and from BLK2 and BLK1/BLU2 (it should also measure 15V)
If it's so you wired correctly the transformer.
Probably you burnt one or both the MC7x012.
Try to measure Vdc on them.
Dario
Old 10th April 2012, 10:38 AM   #1564
50AE is offline 50AE  Bulgaria
Send a message via Skype™ to 50AE
Some new photos. Today I will play with the anode voltages:
http://store.picbg.net/pubpic/D0/84/...bc242bd084.jpg
http://store.picbg.net/pubpic/F7/89/...e64246f789.jpg
http://store.picbg.net/pubpic/7B/84/...271ef87b84.jpg
Old 10th April 2012, 10:44 AM   #1565
bcmbob is offline bcmbob  United States
Billo - A shot in the dark - I had a very strange problem when wiring my JC-2 pre (yellow board). If both 0V wires were connected to the PCB the unit would not function. After combining them in a terminal block and running a single wire to the board, everythings works. Makes no sense to me ( I was going to post about it) but believe me, it was the only way I could get the pre to work.
Might be worth a try. In the photo the Lighter Note is also powered by the same toroid, but the problem was there even when that circuit was not involved.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 10th April 2012, 12:24 PM   #1566
billo44's Avatar
Originally Posted by ClaveFremen View Post
Hi Bill,
Thanks for your help Dario.
I had measured VAC from the transformer before risking applying power to the board (I thought).
I didn't take notes sadly, but I thought I had closer to 15 VAC in my original blue1 - black1/black2 - blue 2 configuration....
Supply voltage here is just a little under 100 VAC/@60Hz.
Here is a low res picture of my notes, red is my actual measured voltages on my DAC.
Bill
Last edited by billo44; 10th April 2012 at 12:29 PM. Reason: drunkeness (only slightly... no more playing with volts tonight!)
Old 10th April 2012, 03:12 PM   #1567
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Here's an unbalancer using miniature 6n16b tubes.... the blog is in italian (but you can use google to translate it into english.
Valvole & Audio: UNBALANCER Project
Does anyone know where I can get a spice simulator for tubes?
Old 10th April 2012, 07:57 PM   #1568
F1 FAN is offline F1 FAN  Canada
Bill
It's not indicated but do you have the 3.3 and 5 volt on the other regs?
Old 10th April 2012, 11:34 PM   #1569
Bill, any of the chip getting very hot?
Old 11th April 2012, 12:22 AM   #1570
billo44's Avatar
All seem OK as per attached picture (small print sorry).
I'll check that out, I haven't left the thing on too long for fear of smoking a chip.
I can start hunting down the signal trace with a scope...?
Don't really know what I'm doing though...
Thanks everyone.
Bill
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
Copyright 1999-2017 diyAudio
