DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 153 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 5th April 2012, 11:46 AM   #1521
50AE is offline 50AE  Bulgaria
Send a message via Skype™ to 50AE
If you guys are going to build the cathode broskie follower only, there won't be voltage amplification so there's a chance the signal will be very low. The first stage in the unbalancer is to voltage amplify the DAC output.
I built both but I upgraded to the unbalancer because of lack of amplification. Both sound great.
Old 5th April 2012, 12:01 PM   #1522
Originally Posted by sterlingmck View Post
Having started working with a kit, not an assembled unit, after the experiment was working .There was a lot of spare parts
Just remove the 4 resisters that pass the I2S bus to the DAC and link the I2S bus from the USB convertor
I used the resisters that were to fit in that location.(I don't really think the the resister are needed, links would do)
Keep the lenghts of the links short
I2S is the link I hoped to use on interface with this DAC. Problem seems to be that I2S links need to be short, which is physically impossible if you don't put the DAC inside the DAC or DVD or CD player. That certainly sort of limits using it with different players.
If you have any suggestion on how to solve that, adding I2S output interfaces on players that would allow longer cables, like a buffer or something, that should be great.
Old 5th April 2012, 12:11 PM   #1523
merlin2069er's Avatar
Send a message via MSN to merlin2069er
The bit teleporter will do that for you...
Teleporter Digital Transfer Module
Old 5th April 2012, 02:34 PM   #1524
Thanks. It looks very good.
Old 7th April 2012, 01:22 PM   #1525
bcmbob is offline bcmbob  United States
Default Looking for Confirmation
Am I correct in assuming (I did browse the thread) that there is no need to add any jumpers or cut any traces when applying Dario's upgrade BOM? I'd rather ask a silly question than see green smoke.
Also would appreciate a little more info on the Brown Dog mod. Soldering is completed but I only found one reference to the bypass cap.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 7th April 2012, 01:37 PM   #1526
yes, you don't need to cut or jump any traces, when applying Dario's BOM
Old 7th April 2012, 01:49 PM   #1527
Thanks idjoel2000. I'm off to the soldering station.
Bob M.
Old 7th April 2012, 01:58 PM   #1528
Reality first!
ClaveFremen's Avatar
Hi Bob, the upgrade BOM requires only components swapping, no trace cuts or bridges.
The OPA827 10nF bypass should be mounted on pin 4 and 8 of the browndog.
I've recently discovered that OPA827 changes a lot as time passes in the bass firmness (the bypass is there for that reason), BTW the bypass don't hurt.
Maybe you could start with the bypass and remove it after 50 hours so you can say us if it's really needed...
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 7th April 2012, 02:18 PM   #1529
Thanks Dario, I will do the 50 hr comparison.
Bob M.
Old 7th April 2012, 08:02 PM   #1530
Hi, I have my unmodded DAC running into my Exposure preamp's tuner input which is marked 10K.
Is this a good match or could I mod the amp to match it better.
cheers
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 02:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 02:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 05:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 01:37 PM
Copyright 1999-2017 diyAudio
