DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 134 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 16th March 2012, 06:43 PM   #1331
Reality first!
ClaveFremen's Avatar
Originally Posted by idjoel2000 View Post
by the way, does anyone have the schematic of the dac module?
Just take a look at the first post...
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition Group Buy 10th Run.
Old 16th March 2012, 09:24 PM   #1332
platenspeler's Avatar
thanks for the reply..
i'm sorry, what i meant is the wires in the secondary output, there will be 4 wires. i was thinking maybe i can get center tapped by connecting the 2 middle wires?
this is my transformer: Buy Toroid Transformers Transformer,toroidal,30VA,0-230V pri,50/60Hz,2x0-15V sec Nuvotem 0030P1-2-015 online from RS for next day delivery.
Based on the datasheet on that site, I think taking the yellow and black together will give you the 0 Vac point. Orange and Red are then the 15 Vac points.
Orange - Yellow/Black - Red
Maarten
Old 17th March 2012, 09:59 AM   #1333
yeah, thanks for the hint.. i got it later last night
Maarten
i thought so.. thanks!
does anyone here compared the stock ak4393/6 module to cambridge audio dacmagic? how's the result?
i'm coming from dacmagic (which i like quite ok), so i wanna know how my dac performs. if at least the ak4393 is in the same level, i think this would be a good upgrade since this dac is a lot cheaper
i have tried my friend's ak4393, but his use broskie cathode follower in the analogue stage. i admit his DAC is MUCH better than my dacmagic, and in par with the elektor 2000 DAC. but please bear in mind, the analogue stage is BCF, not the stock opamp or any other opamp
Old 17th March 2012, 11:11 PM   #1334
billo44 is offline billo44  United Kingdom
billo44's Avatar
Default Sloppy or intentional?
Hi Folks,
I was about to send this board back but I though to check the schematic and it looks like the shorted pins on the two IC may be intentional?
Can someone please confirm this is not just sloppy solder work?
Bill
Old 18th March 2012, 12:09 AM   #1335
Reality first!
Hi Bill,
don't worry about it, if you look at the schematic you'll find those pins are joint.
Dario
Old 18th March 2012, 01:20 AM   #1336
bcmbob is offline bcmbob  United States
Thanks Dario - I saw the same bridges on my new board today and was suspicious. Glad to know the supplier is taking care of us.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 18th March 2012, 04:23 AM   #1337
See post #1077 for details of shorted pins.
Old 18th March 2012, 06:25 AM   #1338
no one?
Old 18th March 2012, 10:49 AM   #1339
billo44's Avatar
Default Thanks
Hi Bill,
Phew! Thanks Dario, and jnewbold,
If anyone is unsure as I was, check out the schematic and post #1077.
Time for some iron ing!
Cheers
Bill
Old 18th March 2012, 12:46 PM   #1340
i'm about to order the transformer for this dac module. i want a separate analogue and digital supply so 9-12V and 15-0-15V will be feed from different transformer
regarding the 9-12V trafo, 2x12V 0.25A should be much more than enough for supplying the digital supply of ak4396, right?
thanks in advance
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 03:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 03:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 06:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 02:37 PM
Copyright 1999-2017 diyAudio
