DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 131 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 14th March 2012, 09:31 PM   #1301
hotiron is offline hotiron  Scotland
hotiron's Avatar
Originally Posted by ggetzoff View Post
Just got done popuating the board using Dario's BOM and I'm only getting 1/2 sec of output and the amp goes into protection.
I've been checking voltages, impedences, and even swapped out the OPA827 on BD, and it checks good (sounds really good) on another dac board.
I've also check component orientation, all check good. Also checked voltages at the 3.3 and 5vdc regs and they seem good.
Here's a pic. What should I be checking? I do get the power led on, but no other leds.
Looks like the heatsink on that regulator is touching the other reg (shorting)
Transformer wiring looks a bit suspect also. Do you have a wiring diagram for the transformer?
If you give up easily Dont start!!
Old 14th March 2012, 09:40 PM   #1302
hotiron's Avatar
What voltages are you getting on the rectifiers?
Old 14th March 2012, 10:47 PM   #1303
ggetzoff's Avatar
I know it looks like that, but it isn't, however, I removed the heatsink anyway just to verify that. The trafo has dual, 15vac secondaries, two greens, two blues. So, I've paralleled the secondaries. Maybe the colors are wrong???? I've tried runing a single secondary and it doesn't change anything. I've measured the secondaries, both paralleled and single at 15+ vac.
1. The negative regulator is showing an output of -12vdc, and the rail at the opamp is showing same voltage, so it's good.
2. The posivite reg is only producing +2.6vdc, and that is what the + rail is showing at the opamp, so clearly, there's a short.
3. I've removed the bridge rectifier and it checks good: it has a vout of 15+. So it's good.
I can't figure out what's wrong at this point and have pulled out plenty of hair over this.
I agree with you that there must be a short someplace, I just don't know what the problem is.
Airline Pilot-If it's not Boeing I'm not going.
"Brain as big as a planet..." {sic} Nelson Pass
Old 14th March 2012, 10:58 PM   #1304
hotiron's Avatar
Try changing out the 7812.
Windings on a toroid would normally have the same colour wires for the taps Eg
15-0-15 would be Blue Black Blue not Blue Black Green.
Old 14th March 2012, 10:59 PM   #1305
ggetzoff's Avatar
I've attached the trafo pdf.
Thanks for looking at this.
Old 14th March 2012, 11:04 PM   #1306
hotiron's Avatar
Ther lies the problem Purple is an earthing screen so it should be wired green- blue/green -blue you can normally tell which blue and green to tie together they would be in the center from the transformer . Post a pic without that screw terminal in the way.
Leave purple disconnected.
Old 14th March 2012, 11:06 PM   #1307
ggetzoff's Avatar
Let me try that.
Old 14th March 2012, 11:09 PM   #1308
ggetzoff's Avatar
Nope, blue/green, blue/green just blew the fuse. Wait a minute, you said blue-blue/green-blue. Let's try that.
Old 14th March 2012, 11:19 PM   #1309
ggetzoff's Avatar
Yes, that was it!!!!! Thank you very much!
Old 14th March 2012, 11:23 PM   #1310
hotiron's Avatar
Is it working now?
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 03:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 03:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 06:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 02:37 PM
Copyright 1999-2017 diyAudio
