DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 126 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 22nd February 2012, 12:14 PM   #1251
how to make a full state analog tube by removing the ic opamp course with i / v made ​​of resistor and capacitor
Old 23rd February 2012, 02:32 PM   #1252
Send a message via Yahoo to minorchange
Originally Posted by Ryssen View Post
I´ve been listening some more,and I think this DAC sound a little darker then the CS4398.What do you others think?
I have both, CS4398 and AK4396. If using opamp as analog stage, CS4398 is much better. When I change to transformer output, I like AK4396 much more than CS4398. Both DAC sound very very good with transformer. But AK4396 has more detail and thicker sound.
Old 23rd February 2012, 03:40 PM   #1253
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
What tranformer did you use with the AK4396?
Regards Åke
Old 23rd February 2012, 11:59 PM   #1254
I tested them with UTC A20 borrow from my friend. Now I'm using unknow 1:1 pair of Russian military transformer which I think be acceptable in comparison to UTC.
Old 25th February 2012, 04:47 PM   #1255
Ryssen's Avatar
Anyone can tell me if LL1585 will work for this DAC?
http://www.lundahl.se/pdfs/datash/1585.pdf
Regards Åke
Old 25th February 2012, 04:58 PM   #1256
100% completed AK4395 with op-amps
Im planning to build another AK4396 with a tube output and compare both units
Uploaded with ImageShack.us
Old 25th February 2012, 05:05 PM   #1257
"I went directly by silver wire - from RCA hot to CS pin 9 (Rxp) , and from cold RCA to CS8414 pin 10 (Rxn)"
"The digital bypass. It is so audible - I can tell you - it is a real thick blanket being removed."
ad1865
Someone tried to connect the CS8416 as the proposed in the link?
Old 25th February 2012, 06:42 PM   #1258
50AE is offline 50AE  Bulgaria
Send a message via Skype™ to 50AE
Is it safe to do? I'd love to remove the cap.
About my DAC - I made the unbalancer . The lampizator's stage I tried sounds like **** compared to this one. It benefits from the balanced output. I can highly recommend it!!
I did it with 6N6P that run at 18mA plate current.
I will do more tests and work before assembly. I will put a separate heater transformer, two rectifiers, bigger choke and better eletrolytics (or not any).
Here's the sweet sounding board again
Next attempts - Better power supply for the DAC - Sallas shunt regs for the chips, better electrolytics.
Old 25th February 2012, 09:57 PM   #1259
hotiron is offline hotiron  Scotland
hotiron's Avatar
Just built one of thes. I am getting system clock from 8416 but no data BCK or LRclock.
Anyone got any ideas?
If you give up easily Dont start!!
Old 25th February 2012, 10:41 PM   #1260
ggetzoff's Avatar
Broskie shows 1K following the diff output pins in his schematic. What value did you use?
Airline Pilot-If it's not Boeing I'm not going.
"Brain as big as a planet..." {sic} Nelson Pass
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 03:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 03:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 06:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 02:37 PM
Copyright ©1999-2017 diyAudio
