DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532 - Page 105 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 2nd January 2012, 11:20 PM   #1041
terranigma's Avatar
Originally Posted by pchw View Post
Did you mean C32, C33 and their corresponding bypasses, C19, C20 (from Dario's components diagram)? Currently, I have Silmic II 22uF/16V.
I haven't the dac kit discussing in this thread. I'm trying to share my experiences of my AK4396 tryouts. I mean analog supply capacitors on dac's #18 pin (+5v) and #19 (Analog ground). You can apply same if there are employed caps between #16 (Low Ref) and #17 (High Ref).
On digital supply (#1 Digital Ground, #2 +3.3V) you can employ a ceramic bypass capacitor alone. If you feel necessary, you can add a ~10uF tantalum as decoupling.
Old 2nd January 2012, 11:31 PM   #1042
terranigma's Avatar
Originally Posted by johnm View Post
You might want to try military spec. tantalum caps on the outputs too (the metal bodied versions, not the cheap yellow or blue caps) - they really do sound quite special.
This very interesting post gets along with my an early post in this thread.
Post #613
But my current favorite is not tantalum. A no-name axial type, blue color, 5uF NOS electrolytic. Yes, an electrolyric. I'm trying everything on everywhere
Old 2nd January 2012, 11:40 PM   #1043
terranigma's Avatar
Originally Posted by ClaveFremen View Post
I do agree, in that position Silmics are not so good, in fact I'm recomending Cerafines there...
I was not in a attitude for offend anyone. I'm just trying to encourage people to attempting their own experiments.
Regards.
Old 2nd January 2012, 11:41 PM   #1044
Reality first!
ClaveFremen's Avatar
No problem at all...
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition Group Buy 10th Run.
Old 3rd January 2012, 12:13 AM   #1045
pchw is offline pchw  United States
Yup, I believe these are the pins connected to the components that I referred to. I will add that to my "explore list".
I think that's the fun of DIY - the ability to hear the changes, if there is any, from parts changes and play them in our own gears. I want to say thank you to Erin to start this thread and many others provided mod suggestion. I have had fun during the holiday with this dac. Especially for a little over $100 of parts altogether, this has been my lowest cost entertainment and yet full of fun in recent winter holidays that I can remember
- Fred -
Old 3rd January 2012, 10:59 AM   #1046
Veggiel is offline Veggiel  Belgium
My current setup employs 100nF Ceramic as bypass and 100uF/16v Nichicon PZ as decoupling. This combination smashed my previous favorite Elna SilmicII's.
Can you give a link to the Nichicon capacitors, I have tryed searching for them but did not find any of 16v only 200v and 400v.
Old 3rd January 2012, 12:21 PM   #1047
terranigma's Avatar
It seems only high voltage series in production nowadays. I found them at a local shop where is not a surprise to find such parts. Nichicon PZ is just as an example. There are in-production candidates from other brands and Nichicon like CA and PX. CA series 100uF/160V has adequate size (16x25mm) despite its very high ripple value. PX 100uF/25V seems a good candidate also.
Green 100nF ceramics are what i used at digital and analog side.
Old 3rd January 2012, 02:51 PM   #1048
terranigma's Avatar
I reinstalled those tantalums with my last setup again. I see no reason for pull up them actually instead of attitude of "try some different". These tantalums took my attention during days that i was trying to figure out difference between dc-coupling (no-cap, direct connect) and ac-coupling (with dc-blocking cap) with my balanced configured gainclone amplifier. I couldn't detect any difference between them.
There is 2.5V DC at AK4396's analog outputs when it refers to ground. Thus, it requires a cap at output when feeding an unbalanced amplifier which is a general case. But, in balanced configuration (instrumentation amplifier) dc is not visible if you isolate your amplifier from your source's (this case AK4396 dac itself) ground.
Old 5th January 2012, 09:41 AM   #1049
erin is offline erin  Australia
Off topic, please forgive me.
I just saw this new DAC on ebay which looks interesting, although only USB input.
TE7022 WM8761 24Bit/96Khz USB DAC Decoder RCA Coaxial Out + USB line | eBay
Old 5th January 2012, 09:44 AM   #1050
Would you be kind enough to describe the sonic difference between the SilmicII and the Nichicon PZ ?
Curious. Thanks
AK4393 burn... CIMONE Digital Line Level 5 24th June 2011 03:12 PM
AK4393 to CS4223? CIMONE Digital Line Level 0 13th December 2009 03:30 PM
AK4393 Serial Configuration Problem Aoxomox Digital Line Level 0 20th March 2009 06:25 PM
AK4393, CS8413 and CS8414 Data Sheets Blue_Max Digital Source 0 23rd December 2004 02:37 PM
Copyright 1999-2017 diyAudio
