Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th October 2011, 11:13 AM   #81
your toroidal should be fine with 2x10v and 2x15 for opams.
Anyway something of 20-25VA with 2x15v and 1 or 2 x9v secondaries would be far enough for this dac.
Old 8th October 2011, 12:50 PM   #82
cobretti's Avatar
20VA transformer is overkill. You need no more than 9 + 9V for digital part (8VA total) and no more than 2x15V for analog part 6VA is more than enough. I wouldn't go with secondary voltages too high because it would create more heat on input stabilizers.
Old 8th October 2011, 01:47 PM   #83
Found some info in the net regarding usb cables, for instance, is there really any point buying some highly reviewed WireWorld Ultraviolet USB for the dac? Mine currently is connected via ordinary computer grey & thick 1m usb cable
Old 9th October 2011, 01:23 AM   #84
cobretti's Avatar
No, there is no point. I also use a basic grey cable.
Old 12th October 2011, 09:50 PM   #85
added toss link input, works great now the dac is even more versatile and beautiful will add some pics later
Old 22nd November 2011, 07:40 AM   #86
Hi everyone
sorry for bumping an old post,but i have few questions about this board,so..
let me first say that my knowledge in electricity is not that great ,
i recently purchased one of this boards,assembled one
(so by this thread most of the capacitor are fake ones),
it sound really great compared to my M-audio FTP stereo outputs
(it connects to a Sure TK2050 2*100w with Audio1st input caps mod)
now for my few dumb questions,
when i connect the board with USB or coaxial,i notice that when a sound is produced there's also a very short "after-sound" immediately after the sound produced ,it's more noticeable in short sounds ,is that amazingly annoying phenomena called "feedback" ?
will changing all big caps will help with this?
or changing the LM's stabilizers ?
(I'm using a single R-core transformer 30va 15v*2 9v*2 if its related somehow)
thank you all for helping a noob & sharing,
otherwise uneducated guys like could not manage in this great hobby !
Old 10th January 2012, 11:49 PM   #87
Nomdi is offline Nomdi  France
Hi everyone !
Does anyone succeeds in adding
optical input ?
I m in serious trouble...
I tried Torx173 and Torx177 with strange results :
I cut the connection between 26c32 and DIR9001.
just a switch to connect the torx, no logic glue,
only inductance and capacitor...
the 5v comes from the 26c32 regulator.
the results ? very weird !
it works but the sound is very loud using
optical input... after a few minutes all smd
regulators get very hot and sounds starts to crack...
And last but not least the DC offset goes crazy !
the protection device of my amplifier start every time
because theres too much dc !!!
if you look at schematics you can see that
the input ground is floating ...
is it the reason to this phenomenon ?
should I use pulse transformer ?
any advice would be appreciated !
thanks to all !
Old 11th January 2012, 10:11 AM   #88
check the scheme here
works fine for me. the only thing is that I use dac's coax input with that.
Old 11th January 2012, 10:19 AM   #89
@dtses
Thanks !
but are talking about the Conrad adapter
or the 74HCT04 schematics ?
in the first case it seems ok because the
dc adapter has no connection with the dac
so you got a galvanic isolation ...
I have doubts about the second solution but I want to implement
the solution onto the board...
I ve ordered Scientific conversion transformers to
give a try...
I will tell you the results...
Best regards
Old 11th January 2012, 02:55 PM   #90
Originally Posted by Nomdi View Post
@dtses
Thanks !
pls refer to post 5 . It works fine, unfortunately I have no camera with me to show you, but it's very simple to add it to the dac.
cs8414 & wm8740 dac (one dac chip) sparkle Digital Line Level 28 28th March 2012 01:10 PM
New WM8740 DAC lordearl Digital Source 4 3rd May 2010 09:51 AM
DIY Dac PCBS ( DIR9001,DF1706,PCM1704) rudee Swap Meet 1 22nd April 2009 02:04 AM
Problem DIY DAC / WM8740 ah79 Digital Line Level 7 14th March 2009 05:20 PM
Copyright ©1999-2013 diyAudio
