Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Wolfson WM8740 DIR9001 PCM2706 DIY DAC
Old 5th May 2011, 08:47 AM   #31
awpagan is offline awpagan  Australia
Originally Posted by dtses View Post
cheers cobretti!
seems to me that it's a cap in the output stage, pls see att. Not sure what is the purpose of it, but maybe someone could explain.
Lookup RC circuits
RC circuit - Wikipedia, the free encyclopedia
it's probably a polyprophylene or cheaper ceramic
Indecision makes the world gone round.
Maybe
Old 6th May 2011, 12:42 AM   #32
cobretti is offline cobretti  United States
cobretti's Avatar
Originally Posted by awpagan View Post
Lookup RC circuits
Never seen a cap with such color coding.
Old 6th May 2011, 01:28 AM   #33
erin is offline erin  Australia
Big Trak Brain and Brawn - Robot Room
check out the comment on capacitors....
Old 12th May 2011, 08:50 AM   #34
dtses is offline dtses
cheers!
finally found and ordered chassis for the dac. It's not the best you can find, though bearing in mind dac's price I suggest it's ok. Moreover front plate could be replaced with some thick black glass for instance. Inside is enough place for pcb and three transformers.
Also ordered new genuine FCs and Silmics to replace all caps and be 100% sure of decent parts used there.
One question makes me feel uncertain. Could anyone pls explain me what is the purpose of quartz here (near the usb) and could it be replace with external clock as further upgrade?! As far as I know in CD players quartz/ clock determines the speed of a disc or some other stuff too?!
Old 12th May 2011, 09:56 PM   #35
gfiandy is offline gfiandy  United Kingdom
gfiandy's Avatar
I think that cap is a EMC filter cap to reduce hf noise on the output cable.
Old 12th May 2011, 11:04 PM   #36
cobretti's Avatar
Please don't take it the wrong way but I still don't understand. What kind of purpose is it suppose to serve? If that should be a low pass filter the cut off frequency is 15.9MHz (I hope I calculated it right). From my point of view it's not supposed to be there at all. But I might be wrong. regards
Old 13th May 2011, 09:43 AM   #37
cyteen is offline cyteen  England
cyteen's Avatar
The 12Mhz crystal on the front edge is used by the PCM2706 you could try this.
The other crystal I can't make out but presume that it is for the dac, If you had a low jitter clock you would be better off using it here than for the pcm2706.
Old 13th May 2011, 05:29 PM   #38
gfiandy's Avatar
It is intended to reduce the radiation of the clock and it's harmonics onto the cable which would form a good antenna to radiate the noise.
This is very common practice in electronic equipment.
A clock typically has significant energy upto it's fith harmonic so a 12MHz clock will have energy upto at least 60MHz.
Regards Andrew
Old 23rd May 2011, 10:13 PM   #39
jackies is offline jackies  United States
Any more comments on the sound? I'm tempted to order one...
Old 24th May 2011, 10:50 AM   #40
I'm on a way to change all psu caps to FCs and 10uf, 47uf to genuine Elnas, at least to be 100% sure that I'm getting maximum from the parts. Swapped diodes to fast Schottky ones.
Also finishing adjusting the case that turned up to be very good for price paid 30 USD (incl. European delivery)
Wolfson WM8740 DIR9001 PCM2706 DIY DACHide this!Advertise here!
cs8414 & wm8740 dac (one dac chip) sparkle Digital Line Level 28 28th March 2012 02:10 PM
New WM8740 DAC lordearl Digital Source 4 3rd May 2010 10:51 AM
DIY Dac PCBS ( DIR9001,DF1706,PCM1704) rudee Swap Meet 1 22nd April 2009 03:04 AM
Problem DIY DAC / WM8740 ah79 Digital Line Level 7 14th March 2009 06:20 PM
