Wolfson WM8740 DIR9001 PCM2706 DIY DAC - Page 16 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 13th October 2012, 06:45 PM   #151
nvduybom's Avatar
I removed I/V stage and replace with LL1544A transformer (ratio 1:2).The sound is better .
Old 17th October 2012, 03:29 AM   #152
nvduybom's Avatar
The configured to replace WM8740 with WM8741 .
Old 6th November 2012, 09:40 AM   #153
cheers!
I have a strange hissing on the right channel, it could start after an hour or two or could be heard even after 5min once the DAC is turned on. It's quite loud and very disturbing, as to the the music it continues to play on the same volume. Then after a minute or even 3-5 it suddenly vanishes like it appeared. The DAC operates with open lid, should not be any overheating. All joins have been resoldered, pbc checked for any micro tin remains.
Once it happens all power supplies show same correct voltage as before, what else could be checked here and what theoretically could be the reason of such hissing/ cracking white noise?
Old 8th November 2012, 12:59 PM   #154
newbie here. i plan to connect this DAC to Lm4780 amp. Is the op-amp needed for better sound? or i can bypass the op amp?
Old 17th November 2012, 03:30 PM   #155
noSmoking's Avatar
Hi Singod87,
If you have the newer version with the pots to adjust DC on output,and your amp doesn't need a preamp, then you can jump it and see if it has enough gain,also as you know opamp's have different sounds ,if any DC on the output of the dac output, use a input cap or check your amp input and see if there's one there then you won't need to add that cap,
Post back your results ,What amp are you using,It sounds good with gainclones!
Happy Listening,
NS
cs8414 & wm8740 dac (one dac chip) sparkle Digital Line Level 28 28th March 2012 02:10 PM
New WM8740 DAC lordearl Digital Source 4 3rd May 2010 10:51 AM
DIY Dac PCBS ( DIR9001,DF1706,PCM1704) rudee Swap Meet 1 22nd April 2009 03:04 AM
Problem DIY DAC / WM8740 ah79 Digital Line Level 7 14th March 2009 06:20 PM
Copyright 1999-2017 diyAudio
