| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#141 | |
Did you notice any difference with TeddyPardo? |
#142 | |
Although I have not tried, because I haven't finished the DAC. But the sound of the Wolfson should be cleaner. |
#143 |
Finally, finished with the case and all in/out RCAs.
Added separate 3rd Salas +5v for WM8740's analogue part, removed smd 5v regs. |
#144 |
Looks good ,I also swapped out the caps for oscons and all the regs,I have some fast switch diodes but haven't got around to replacing them yet ,I ordered (4)blank boards and got the newer ones with the pots near the output opamps,they adjust dc offset,mine went to zero and stayed there(grounded input) to adjust.
It sounds great compared to some other dacs I have used,so I'm Happy! I would like to use the wm8741 for the digital aspects,volume control and also filters has anyone done this and is it worth the time ,I built the first version of heartwinters Dac and it sounds good I switch the filter with a 3 pos switch and was wondering if it's worth going futher? Nice build and case! ![]() ![]() ![]() ![]() Cheers, NS |
#145 | |
#146 | |
#147 |
besides the new version of this chip and new improved numbers, is there any point swapping the original one in this DAC? Has anybody done any comparison?
#148 |
I removed USB, 74HC157 chip and replaced all 47uf Elna capacitor with 33uf tantan, Opam with LF356H gold pin .The sound really improved.
I have idea use I2S signal of airport express connect direct to WM8741 and output with transformer LL1544A (600:600) . |
#149 |
Hi nvduybom,
Looking good,I also replaced the regs on top side because I haven't seen ones so thin and also mine got too warm for me so I heat sinked them,Just a small flat aluminum heat sink fixed it, I haven't changed out for a 8741 yet,I have another dac that has 8741 in it ,but it also has a good clock and seperate power supplies for anolog and digital,it also gives you some digital filters and other digital (software/hardwire) features,I hard wired it with a switch and It sounds good ,best dac I have built so far,as far as sound goes, it was one of heartwinters boards on diyaudio. Have fun! NS |
#150 |
Hi noSmoking,
Thanks. I checked the regular 7812 and 7808 is ok (no hot). I will try connect direct from WM8740 to output transformer LL1544A. I care the WM8741 dac kit of twistedpearaudio, it look good. Best regards Van Duy |
| cs8414 & wm8740 dac (one dac chip) | sparkle | Digital Line Level | 28 | 28th March 2012 01:10 PM |
| New WM8740 DAC | lordearl | Digital Source | 4 | 3rd May 2010 09:51 AM |
| DIY Dac PCBS ( DIR9001,DF1706,PCM1704) | rudee | Swap Meet | 1 | 22nd April 2009 02:04 AM |
| Problem DIY DAC / WM8740 | ah79 | Digital Line Level | 7 | 14th March 2009 05:20 PM |
