Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 28th January 2012, 01:19 PM   #111
cobretti's Avatar
Originally Posted by Antonside View Post
Ive got 1.5 version too. I replaced the diodes and regulators to originals and i ordered ELNA Cerafine caps from ebay but i afraid that they are fake too
May I ask where those caps are coming from? If they come from east, they might be (will be) most likely fakes as well. Why don't you use good Nichicon caps? Just a thought.
Old 28th January 2012, 02:58 PM   #112
They coming from china. Now i use nichicon capacitors in my dac but they can be fakes although they looks genuine they come with the kit.
Maybe some one know a good seler on ebay who sale original parts ?
Old 28th January 2012, 05:07 PM   #113
Since ELNAs from eBay are mostly fake, I switched to Panasonic, Sanyo, Rubycon and Nichicon, available from Farnell, Mouser and ELFA. With such suppliers you can always start a dispute about the quality and I haven't encountered counterfeit goods from these suppliers.
Old 29th January 2012, 11:36 AM   #114
cobretti's Avatar
Mouser, Digi-Key, Newark won't sell you fakes. If you can't buy from suppliers like these and let them ship it to you, then, I think it's better to find reputable local dealer instead of buying parts on eBay. I would never buy anything from China again, I have bad experience... not even kitchen knives.
Old 15th February 2012, 07:53 PM   #115
hi,
found very interesting article how to improve standard LM317 regulator circuit. I wonder would it give any improvement with DAC's 7812 & 7912 regs
Old 16th February 2012, 12:05 AM   #116
cobretti's Avatar
Well, it depends what the existing noise looks like. As a matter of curiosity, I just measured my output stage (L7912ACV from ST , can not read the positive one) and I got 35uV of noise on both positive and negative rails. You would have to try the specific circuit for yourself and compare it if gives you any audible benefit. 35uV is low enough number for me, hence I will not try to do any mods. If you want a tip on a low noise regulator, I measured SSR01 from Sjostrom and it produces about 2.3uV (add some percentage +- for error) of noise. I used cheap OPA134 opamp in SSR01. I think if you put genuine regulators, not those like mine I received in the kit, you shouldn't worry too much. But on the other hand, I would love to hear feedback from some experiments.
Old 20th February 2012, 01:58 PM   #117
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Is anyone using both oscillators (22.5792MHz, and 24.576MHz) and muxing them?
Old 20th February 2012, 05:26 PM   #118
gfiandy is offline gfiandy  United Kingdom
Audio Engineer
gfiandy's Avatar
I haven't done it with this set up but I have designed multiple clock systems in the past. If you want to do this I recommend creating a kill circuit for the clock you are not using as the ineraction between the two sees to be enough to cause audible degradation. Presumably by introducing decision threshold jitter.
Andrew
Old 20th February 2012, 06:33 PM   #119
miklos is offline miklos  Canada
That's interesting, considering everything you own comes from China
miklos
Old 21st March 2012, 08:11 AM   #120
cheers,
I wonder how many people ordered and built this DAC?
It has one feature that needs to be improved for sure. I guess everybody experienced it. When you turn the power switch off, cracking noise comes from the analog output to the amp and it's quite annoying and even terrible on high volume. As I've understood it happens due to direct opamp output and some filter or muting circuit should be added, am I right?
cs8414 & wm8740 dac (one dac chip) sparkle Digital Line Level 28 28th March 2012 01:10 PM
New WM8740 DAC lordearl Digital Source 4 3rd May 2010 09:51 AM
DIY Dac PCBS ( DIR9001,DF1706,PCM1704) rudee Swap Meet 1 22nd April 2009 02:04 AM
Problem DIY DAC / WM8740 ah79 Digital Line Level 7 14th March 2009 05:20 PM
Page generated in 0.11508 seconds (75.54% PHP - 24.46% MySQL) with 11 queries
