Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Wolfson WM8740 DIR9001 PCM2706 DIY DAC
Old 16th January 2012, 08:39 PM   #101
dtses is offline dtses
you mean swapping quartz to dedicated clock? (pls see att.)
according to the scheme that would affect only usb input.
btw, I didn't change all stock resistors and film caps, hope that it's not so grave as elkos and regulators.
Old 17th January 2012, 10:01 PM   #102
cobretti is offline cobretti  United States
cobretti's Avatar
DIR9001 receiver has actually built in clock. Never mind. That cheapo crystal you circled is probably OK for USB input in this application. I use my DAC with SPDIF connection primarily, feeding it straight from Xonar sound card instead of using USB as I did before. I think it sounds better that way. I am just lacking 192kHz sampling, that DAC can not handle.
Old 20th January 2012, 01:30 AM   #103
apoopoo999 is offline apoopoo999  United States
Here's some pics from a Azur 640C. It has 2 8740 in dual differential mode. It uses 6 NE5532. There are some little black SMD on the voutrp, voutlp, voutrn and voutln. Anyone have any ideas what these are for?
Uploaded with ImageShack.us
Old 21st January 2012, 12:46 PM   #104
cobretti's Avatar
Probably I/V stage input resistors.
Old 21st January 2012, 01:11 PM   #105
Antonside is offline Antonside
Hi everyone has someone get the circuit diagram of the DAC from the supplier ?
Old 22nd January 2012, 09:52 AM   #106
Chii is offline Chii  United Kingdom
Hi all Ive just started building one of these too, i plan to build 2 long turm
The kit I have is a 1.5 version which has a larger crystal package being used unfortunatly the caps and other parts on this kit are fakes so I am pretty much ordering everything in from scratch.
I have a question about the rectifiers two of mine are shatterd will Schottky SR5100, 5 A 100V be ok for this role?
With thanks
Andy
Old 26th January 2012, 10:20 AM   #107
I've got it from the seller, see 1st page.
Chii
you can use it, but that would be like overkill for power supply. I replaced stock fakes with fast 1N5819. Moreover they are like almost free.
Btw, where did you get 1.5 version? Could you please attach any pics?
2 all
I'm thinking about replacing all resistors with Dale 1% 1/4w and 4 in parallel per channel on the opams' output. How do you think, would that be a noticeable improvement?
The second upgrade should be shunt regulated PS instead of 7812 & 7912 regulators for opams, though not sure if I have space left for that...
Old 27th January 2012, 09:27 AM   #108
Hi DTSES
eBay - The UK's Online Marketplace is the auction I got the kit from.
Image:
Old 27th January 2012, 02:40 PM   #109
Ive got 1.5 version too. I replaced the diodes and regulators to originals and i ordered ELNA Cerafine caps from ebay but i afraid that they are fake too
Old 28th January 2012, 06:43 AM   #110
At this point i have dale 1% resistors on order to put in instead of the ones supplied, Cerafines for the 1uf, 220uf and larger voltage 47uf, Oscons for the 47uf 16v. Rifa's for the 3300uf and all of the film caps are now WIMAs. Ive also changed the op amps out for a spare set of BB627BP's i had on the shelf.
I am hoping that this produces something that will challenge my modded delta 290's and alpha 9's to show what there capable of. If not it will be relegated to the media center in the bedroom.
Wolfson WM8740 DIR9001 PCM2706 DIY DACHide this!Advertise here!
cs8414 & wm8740 dac (one dac chip) sparkle Digital Line Level 28 28th March 2012 01:10 PM
New WM8740 DAC lordearl Digital Source 4 3rd May 2010 09:51 AM
DIY Dac PCBS ( DIR9001,DF1706,PCM1704) rudee Swap Meet 1 22nd April 2009 02:04 AM
Problem DIY DAC / WM8740 ah79 Digital Line Level 7 14th March 2009 05:20 PM
Resources saved on this page: MySQL 13.04%
