Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 31st March 2011, 08:43 AM   #1
Default Raysonic servo board/laser pk up repair(DIY)
I have been informed that it is one or the other problems(Player quit reading)
Is this a easy fix project or a DO NOT ATTEMPT project.
Has anyone had this problen.
thanks john
thanks John
Old 31st March 2011, 04:07 PM   #2
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
OK. Which model number is the player ?
andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 31st March 2011, 08:05 PM   #3
wow...that is important.
CD-128
thanks John
Old 31st March 2011, 09:13 PM   #4
poynton's Avatar
Have you have cleaned the lens (carefully) and have you also cleaned and lightly regreased the mechanism??
The CD mechanism is the very common KSS-213 from Sony.
These are easy/cheap to obtain and change if cleaning has no effect.
(remember to unsolder the antistatic solder blob after fitting)
Andy
Old 1st April 2011, 10:48 AM   #5
what happened is that the reading stage after you put the lid down does not spin and the display says "NO DISK" and then "ERROR"...I have tried several disks and unplugged several times with no avail
I was in contact with steven at raysonic and have these parts coming at his request.If they are easy to install,I will do it with the help of the DIY community of course.I love this player but not sure of some great easy upgrades without sending it to Parts Connection and paying $$$$ and I would rather not if the drive goes alot..I donnot really have a ton of hours on it.
thanks
thanks John
Old 10th April 2011, 04:44 PM   #6
Has no one ever touched one of these players?
thanks
thanks John
Old 10th April 2011, 05:52 PM   #7
Mooly's Avatar
Never even heard of them
Fault finding follows a definite path though... also did you replace anything.
1. Does the lens do a focus search routine when the lid/drawer or whatever is closed or if you defeat the interlocks etc. The spindle motor should not spin at this stage.
2. Can you see (looking from a distance) the laser lighting during focus search, it will be a dim red glow.
3. With the power off, if you manually turn the sled so that the pickup is moved toward the outer part of its travel and then power up and close lid etc does the sled return to the center. That proves more than you might think.
If all that is OK than the laser is possibly the first suspect without doing more involved tests such as laser current and confirmation of the FOK (focus OK) signal.
A simulation free zone. Design it, build it, test it.
Old 11th April 2011, 04:45 PM   #8
poynton's Avatar
It would be very helpful if you could post (as attachments NOT using hosting software!) some photos of the main board.
Andy
Old 16th April 2011, 11:19 AM   #9
Hi guys
I will post pics as soon as I recieve parts.
thanks
thanks John
Old 16th April 2011, 10:38 PM   #10
actually,the 6 moons review shows alot of pics of the insides of the Raysonic CD-128
thanks John
off board DC servo - feasible? CharlieLaub Chip Amps 8 12th February 2011 07:57 PM
Need servo board for DC7 mechanism mildead Digital Source 1 2nd March 2008 09:30 PM
Broken Servo Board diyman Digital Source 1 26th December 2006 06:24 PM
miracle: all solid state oszillator with 160 ps pk-pk jitter capslock Digital Source 3 17th September 2004 12:49 PM
Repair a servo circuit of TEAC VRDS 7 kwen10 Parts 0 14th July 2004 10:36 PM
Page generated in 0.09195 seconds (78.16% PHP - 21.84% MySQL) with 10 queries
